Old 02-02-2014, 06:36 AM
ukfan1 ukfan1 is offline
Vehicle: 2011 ram quad cab 4x4
Trim Level: slt sport
Color: silver
ukfan1 is on a distinguished road
Default suggestions on tires
I know it's on this site somewhere, but I need some help on tires. I've got a 2011 ram 1500 quad 4x4. Going to put bilsteins set at 2.8 in front and 1 inch coil spacers in the rear. I'm running on 20's. I don't like the over stuffed wheel well look, or the little tire look. If anyone has this set up could you please post pictures, or tell me what size and kind of tires would look best. Wife has given me green light to do some mods, and I'm not real adapt at automotive stuff. Thanx!
Old 02-02-2014, 12:16 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Stock tires are 33" in diameter. If you go to a larger diameter, like a 35" you will lose some performance, probably lose mpgs as well. Speedometer can be corrected with a tuner. Even if you keep stock size tires, there are much better tires available than the crappy Goodyears. If you go to some sexy off road mud tire, they may be noisy or ride worse. I like Discount Tire and the tire Rack web sites, you can read reviews from owners. If you use your truck off road a lot then a mud tire might be the answer.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-03-2014, 09:36 AM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2013 Ram 1500 Sport
Rep:120
Firemedic10584 will become famous soon enoughFiremedic10584 will become famous soon enough
in my opinion, a 275/65/20 BFG AT tire would be perfect. I ran that size on just my level kit with my truck and it looked great and fit the wheel well perfectly. Its a 34.1" tall tires and I think 11" wide.
Old 02-03-2014, 11:34 AM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
For a good A/T the BFG A/T and the Toyo open country AT2 are some great tires. I have a thread in my sig regarding leveling the tires that you may find helpful.
Tow mirrors up for the haters
Old 02-03-2014, 06:32 PM
TTaylor34 TTaylor34 is offline
Vehicle: 2013 Dodge Ram 1500
TTaylor34 is on a distinguished road
I'm looking to run the same set up with my truck (Bilsteins @ 2.8 w/ 1 -1 1-2 inch rear spacer.)
I haven't pulled the trigger for the same reason, i can't decide on the right Wheel/tire combo to run with the level. My stock tires measure a little over 32". And i don't think i want a 35 to cause any rubbing or to look stuffed in there. I think i am leaning towards going down to an 18" wheel and running a some kind of 33 "A/T. I think the 18" wheel will give the 33's a more aggressive look...
Any suggestions or input? Anybody leveled with 18's?
Thanks!
Old 02-03-2014, 06:56 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
If you want to keep the stock wheels and don't want a stuffed look then 295/60/20's are the best option for you. They're about 34" tall which looks great on a leveled truck. As CHP said, check out the Guide to Leveling & Wheel and Tire Sizing linked in either of our signatures. I put a bunch of links in there to different threads with pictures of different set ups.
Old 02-03-2014, 07:51 PM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
Ive got rough country setup with 35 12.5 20 and I love it
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 02-10-2014, 11:55 AM
WhiteLightning88 WhiteLightning88 is offline
Vehicle: 2014 Ram 1500
Trim Level: Express 4x4
WhiteLightning88 is on a distinguished road
Hey guys, I ordered the bilstein 5100 adjustables for the front and am planning on running them at 2.1" for a clean leveled out look. Having a hard time deciding what size tires I want. I'm pretty set on bfg's and am thinking 305-55r20, 285/65 r20, or 295/60 r 20. I'm also putting them on KMC XD series crank wheels that have a 0 offset. I want them to fill the wheel well out nicely and not stick out too far. Anyone with pictures or suggestions?
Old 02-10-2014, 12:31 PM
Trim Level: SXT 4x4
Rep:2802
Go to the thread in the signatures of me and Brandonjansen. There is pictures of members runnning different set-ups. 1 has XD cranks with 0 offset, but I believe they are 17".
Old 02-10-2014, 11:56 PM
Captain10's Avatar
Captain10 Captain10 is offline
Vehicle: 2007 Dodge Ram
Captain10 is on a distinguished road
Does the rough country setup come with the same type of struts as the bilstein 5100?
35x12.5 Federal Couragia M/T|20x9 Ballistic Jester 0 offset|Bilstein 5100 Maxed|Magnaflow Muffler|ARE Tonneau Cover|LED Tailgate Light Bar
