Old 02-04-2014, 11:12 PM
Hornet Hornet is offline
Vehicle: 2013 RCSB Ram
Rep:470
Originally Posted by mygt8a4re View Post
Doesnt the Spohn udjustable Panhard bar allow for adjusting fore/aft movement, As in pinion adjustment and not side to side movement? I keep seeing people talk about the Spohn bar to correct the off center diff after lowering, am I missing something?
We're talking the panhard or track locator bar,it's the bar that's behind the rear axle,and locates the axle side to side in the chassis.
This single arm sits parrallel to the diff housing
The bars you're referring too are upper and lower control arm bars,they locate the axles fore and aft movement in the chassis,and allow you to set pinion angle.
These 4 arms run parrallel to the frame,and mount in front of the diff housing
Spohn makes both sets of arms
Old 02-05-2014, 12:04 AM
mygt8a4re's Avatar
mygt8a4re mygt8a4re is offline
mygt8a4re is on a distinguished road
Ahhhh, ok, gotcha! Thank you for the explanation!
MYGT8A4RE = My GT Ate A Ferrari, been using that screen name for years....
