Old 01-26-2014, 08:40 PM
Dcar Dcar is offline
Vehicle: N/a
Dcar is on a distinguished road
Default 7" Cst lift with 20x12 and 35s?
This doable with a 2wd? Looking at the motometal 962 20x12 -44
Old 01-26-2014, 09:26 PM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
No expert, but I think another member has the cst 7" and needed a 3" body lift on top of that to fit the 20x12 -44. I will let you know if I come across his thread.
Old 01-27-2014, 06:44 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Found this the other day. Exact same setup you are looking for.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 01-27-2014, 08:11 AM
Vehicle: N/a
man that does not look like 7" of lift
Old 01-27-2014, 12:29 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Since you only plan on running 35's you should be able to clear that set up.
Old 01-27-2014, 09:04 PM
LoudAndProud's Avatar
LoudAndProud LoudAndProud is offline
Vehicle: 2008 Dodge Ram 1500 QC
Trim Level: SLT Big Horn QC
LoudAndProud is on a distinguished road
His huge rims might make the lift look smaller
Old 01-27-2014, 09:37 PM
gingy36's Avatar
gingy36 gingy36 is offline
Vehicle: 2012 Ram 1500 Express
gingy36 is on a distinguished road
I got the CST 7 and love it. Remember though 7" lift on our 2wds is going to look different than 7" on a 4x4. In all honesty, If I were to compare my truck to a 4x4 lifted truck, my height is closer to a Country 4" inch lift rather than a 6" Rough Country lift. If you want more lift then you're going to need to add a 3" body lift.
Look at this video man. He's got a 7 CST with a 3 PA body lift. he's only got 35s with a 20x12 wheel. If you watch this video and look at the comments he talks about he would rub at full lock if he had anything bigger than 35s. Which leads me to believe that you WOULD rub with 35s on a x12 wide rim with ONLY a CST 7. If you had a body lift. Different story
