Old 01-25-2014, 08:43 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
Default Aftermarket fog lights controlled by stock switch.
I have a set of PIAA fog lights I am going to install on my truck. I want to use the stock switch so they work like the original fog lights did. I am using a relay to switch power to the lights. I would like to use the original fog light wires to control the relay. I think the lights may be on the CAN bus and the relay may not be enough load on the circuit. Does any one know if this is true and if it is what would I need for a resistor to get it working?
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 01-25-2014, 08:59 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I have a 2013 and I don't think the fog lights are on the Can Bus electrical system.
I put HID lights in my fog lights and used a wiring harness which uses the OEM fog light wiring to trip the HID fog light relay. The wiring harness has no resistors and I get no light out warning.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 01-26-2014, 08:48 AM
Rep:23
Greg
Thanks for the information. I am going to install the fog lights and kit today. Maybe they will work. I am going to do some more poking around with a meter before I put power to them. If they are not on the CAN bus I should be able to use one of the power wires to the original fog lights to control the relay and leave the other original power wire disconnected.
Old 01-26-2014, 07:08 PM
Rep:23
I installed the fog lights today. They work fine using the original fog light power to control through relay for the new lights.
Old 02-01-2014, 01:14 AM
res1551cue's Avatar
res1551cue res1551cue is offline
Vehicle: 2012 Ram 1500 QC
Trim Level: ST with Ram Box
Rep:37
res1551cue is on a distinguished road
You have pictures of how you installed/wired the lights?
2012 Ram 1500 ST Quad Cab Flame Red with Ram Box
Upgrades: 6000K Fogs; 2013 OEM Projectors; Black 5" Oval Nerf Bars; Plasmaglow Fire and Ice Tailgate Bar; BakFlip FiberMax Bed Cover; LEDs; Bed Cover Lights
My Build
Old 02-01-2014, 10:33 AM
Rep:23
The lights are installed on a Iron Cross bumper. I will try to get pictures this weekend. I do like the lights. They put a lot more light on the road in front of me. The middle of the pattern looks yellow and the sides are more white. The lights are supposed to be fog lights but they don't have the sharp cutoff like other aftermarket fog lights I have used over the years. They surely don't light up the road like LED lights will but I could not find LED for lights I cared for. I am thinking about getting the LED driving lights that the bumper is set up for.
Old 02-01-2014, 11:35 AM
BlkXpress's Avatar
BlkXpress BlkXpress is offline
Vehicle: 2014 Dodge Ram
Trim Level: Black Edition
BlkXpress is on a distinguished road
like to see this setup got these to install behind grill http://www.myhellalights.com/index.p...s-black-magic/
kn drop in/mufflex delete/black powder coated tips/smoke tails rear cab light/black mgp covers/tonnopro/tinted windows/bed matt/matt black stripes
