Old 01-25-2014, 12:09 PM
Cbr1107 Cbr1107 is offline
Vehicle: 2010 Quad Cab 4x4
Trim Level: Slt
Cbr1107 is on a distinguished road
Default 2010 Ram: Max Tires w/ No Rubbing
I am sure this has been covered on here before so please forgve me if it has. I have tried searching in various places and I can't find the answer I am lookng for. Now to the question at hand....
I have a 2010 Ram SLT quad cab w/ 4wd. I currently have Bilsteins on the front and set at the 2.1in setting(the second setting from the top).
I am in the market for new wheels and tires. For the wheels I am looking the Mamba M2X in 18in x 9. Like these: http://www.tirerack.com/wheels/Wheel...All&sort=Brand
For the tires I would like BF Goodrich All-Terrain T/A KOs: http://www.tirerack.com/tires/tires....rrain+T%2FA+KO
Any idea what is the biggest tire in that brand I can fit on that wheel with no rubbing?
I am considering the LT275/70R18. I am thinking they are the best choice for the size/money. They are $209 vs $290+ for the next size up and looking on a conversion calculator aren't that big of a difference in size. Would the LT275/70R18 tires fit with no rubbing at full lock up in either direction?
I have no idea if the wheels have any sort of offset and whether or not it even comes into pla here.....
Old 01-25-2014, 05:10 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:349
With 9" wide rims you should be able to go +19 on offset and fit 275/285 without rubbing. Wider and you are going to need more offset.
333Half the beast
I used to be
Old 01-25-2014, 07:58 PM
Trim Level: Slt
Thank you for your reply. Those wheels and tires at 275/70R18 aren't much bigger than what came stock with the 17in wheels. Once I know for sure they won't rub I will go a head and buy the wheels.
Old 01-25-2014, 08:28 PM
Trim Level: Slt
Any idea how the offset and back spacing on that wheel will look? Will it make the wheels/tires look sucked in or pushed out at all compared to the factory 17in wheels?
Old 01-25-2014, 10:30 PM
h2oman's Avatar
Rep:349
They will stick out about half an inch.
333Half the beast
I used to be
Old 01-26-2014, 12:48 AM
Trim Level: Slt
1/2in isn't bad. That I can live with. I just hate to spend the money on new wheels and tires only to have them rub. I see people do that all the time and just live with it and it just ends up being a waste of money. Thank you again sir for the input.
Old 01-26-2014, 02:45 AM
h2oman's Avatar
Rep:349
Post up some pics when it's done.
333Half the beast
I used to be
Old 01-26-2014, 10:19 AM
Trim Level: Slt
Certainly. I just wish I had a picture of the stance of the truck before the bilsteins. Ha
Old 01-26-2014, 10:41 AM
h2oman's Avatar
Rep:349
This is how far my 275's stuck out on the stock 20's that had +19 offset.
I don't like mine sticking too far out. So I went with +25 on 17's with my 285's. Hopefully this will give you an idea of what to expect.
333Half the beast
I used to be
Old 01-26-2014, 11:30 AM
Trim Level: Slt
Thank you for the pictures. I meant that I wish I had stock pics of my truck. Haha. It sat like a 2wd. Horrible.
So I'm not sure if it's the angle or what, but in the 1st picture with the 275s on the 20s with +19 offset, it looks like they stick out quite a bit further than 1/2in. Is it the camera angle or did they stick out more like 4-6in? The wheels I want are +19 offset and I definitely don't want them out that far. Any idea how wide those 20s were? The wheels I want are 18 x 9, so if they 20s were an inch or 2 wider, would that account for them sticking out so far in your picture as opposed to the 1/2in you thought they might stick out on my truck?
