Old 01-22-2014, 07:02 PM
dauer53's Avatar
dauer53 dauer53 is offline
Vehicle: 2011 1500 Quad Cab Sport 4x4
dauer53 is on a distinguished road
Question HID's with Canceller and Relay Harness??
I was looking for a write up on how to install a relay harness with code cancellers if anybody can help? I installed the H11 clearview HID kit and added code cancellers but I'm still getting some flickering. Their Customer Service said I would need a relay harness to eliminate that and well... I have the harness but have no clue how to install it with cancellers. Any help would be greatly appreciated.
Old 01-22-2014, 08:14 PM
Talon66 Talon66 is offline
Rep:92
Talon66 will become famous soon enough
Use the Wiring Harness, don't use the cancellers
2013 Ram 1500 CC Black
Factory: Hemi, 8spd, 4 Corner Air suspension, Rambox
Mods: DIY FX-R Projectors w/4300k & 50w, Custom Dual Relay Harnesses, Tinted, Debadged, blacked out emblems, Stainless Works LT Headers, AVS Low Pro Visors, Magnaflow #12569, Kicker Soundgate, Diablo DCX - HF Tuned
Old 01-22-2014, 08:29 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
^^^^What Talon said
Big Red my old 2011 Sport
Old 01-22-2014, 10:47 PM
dauer53's Avatar
Thanks fellas... I'll give it a shot as soon as it get's over 30 degrees here!
Old 01-27-2014, 08:57 PM
dauer53's Avatar
Well, I installed the harness without the cancellers and still had the flickering. On top of that the relay was making a loud continuous buzzing so I read on another thread to bridge the 85 & 86 poles on the relay with a 470 uf 35v capacitor and... now the lights won't turn on at all. I'm literally in the dark at this point??
Old 01-28-2014, 09:24 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Are you getting a bulb out error on your dash? Rams are hit and miss with HID's. Some will use cheap ebay harnesses and have no problems. Others have used expensive harnesses with built in resistors and capacitors. There are even canbus ballasts that some are using. Any way to post a picture of how things are wired? More information on the ballasts and capactiors would help.
Did you splice wires to install the capacitor?
Plug in the capacitor into the factory plug and the relay harness... That fixed their issue. When installing the capacitor make sure red goes to red and black to black (correct polarity).
