Old 01-21-2014, 02:40 PM
Wayalife Wayalife is offline
Wayalife is on a distinguished road
Default 4 Inch RCX lift install
For the ones that installed their own lift I was just wondering how it went. If it went pretty smooth or do wish you would have had it installed. Im a engineer on a boat so I know what end of a wrench to use I just wonder without a shop and lift at use is just worth having someone with all the right things doing it Im just doing my best to keep the dollars down
Old 01-21-2014, 02:54 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I installed my 6" RCX lift on my 1500 in my driveway on jackstands. Worked perfectly fine. I also have an air compressor with an impact gun and other air tools which made the work quite a bit faster and easier. The worst part about it was cutting off the factory rear cross member bracket and drilling a few holes for different things. The rest was fairly simple. I don't regret doing it at all. For one I enjoy doing all the work on my trucks, that's half the fun... plus it saved me a good chunk of change. I plan on lifting my 3500 in the exact same way. Except this time I have a shop big enough to roll it into rather than a driveway.
Old 01-21-2014, 04:17 PM
Cool thanks I guess the cutting I saw on the install info was what concerned me the most but I think between me and my buddy we should have all the tools we need it looks pretty straight forward but you can never tell till your elbow deep in it but thanks for the info
