Old 01-19-2014, 03:47 PM
NY Ram 86's Avatar
NY Ram 86 NY Ram 86 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Tradesman Express
Rep:19
NY Ram 86 is on a distinguished road
Default Soldering Resistor to LED Bulb Help
I am trying to fix the issue of an error message of my lights being out because I just installed LED's for my cargo/3rd brake light and my license plate lights. I am using a 100 Ohm - 1 Watt resistor for a 194 LED bulb. I do not know where exactly to solder it. Onto the bulb itself or into the socket? I have also seen that I only need to use one for the cargo/3rd brake light (socket with 2 brown and 2 black). Some help with this would be great! I couldn't fin any answers in the forums that already deal with these issues.
Old 01-19-2014, 06:32 PM
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
On my cargos i only added 1 resistor. I just stuck it into the back of the plug. Where the wires comes into the plastic. On my map lights i just pushed the resistor in with the bulb too. I only soldered to my dome light. I went to each side on the metal on top of the bulb
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 01-19-2014, 06:52 PM
NY Ram 86's Avatar
Rep:19
Awesome, so just to clarify, you pushed the resistors leads into the back of the socket? The resistors don't touch the bulb? Could I also do this with my license plate lights?
Old 01-19-2014, 06:59 PM
Jhouse's Avatar
Vehicle: 2014 ram
Rep:163
Correct. I stuck the resistor in and just bent them away from the bulb
Old 01-19-2014, 07:01 PM
NY Ram 86's Avatar
Rep:19
Thank you. I am going to go outside right now and try this. I hope it works for me because I am driving myself crazy with this LED situation.
Old 01-19-2014, 07:02 PM
Jhouse's Avatar
Vehicle: 2014 ram
Rep:163
Whats happening with them?
Old 01-19-2014, 07:07 PM
NY Ram 86's Avatar
Rep:19
Well a few days ago I installed LED's into my two cargo lights, 3rd brake light and two license plate lights. All work fine and look awesome. Now I get the error message that my license plate lights and right rear brake light is out. So I've researched and learned I need resistors. I bought 100OHM 1 Watt resistors. But now I have no idea how and where to solder them onto the bulb (if it's even supposed to be on the bulb). I've been trying to find any sort of tutorial or photos of what I need to do and I can't find anything. So I'm going to try your suggestion. I want to purchase some more for my tail lights and reverse lights but I'd love to not have to go through this situation. And I don't know if I am able to use canbus bulbs or not.
Old 01-19-2014, 07:10 PM
Jhouse's Avatar
Vehicle: 2014 ram
Rep:163
For tailights u need much bigger ones. Let me see if i can get a pic for u
Old 01-19-2014, 07:12 PM
NY Ram 86's Avatar
Rep:19
I know that the tail lights require a large resistors which I will purchase when I order the bulbs. But for the cargo and license plates?
Old 01-19-2014, 07:57 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
I suggest that any further bulbs you buy are canbus ones... Then you don't need to worry about resistors.
S S H A D O W
