Old 01-18-2014, 11:40 AM
route12v route12v is offline
Vehicle: 2008 Toyota Tundra
Trim Level: Base
route12v is on a distinguished road
Default LED turn signal/parking lights
I installed new LED turn signal and parking light bulbs along with the resistor to make sure they don't flash fast. Here's the kicker. The front and rear signals flash properly but the mirror lights flash fast and so does the indicator inside the vehicle. Anyone know how to fix this as I have learned this truck does not have an actual flasher that can be changed????
Old 01-18-2014, 03:53 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Did you use a resistor at each turn signal? You need one for each led, so you need 4 total.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 01-18-2014, 10:11 PM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:584
You need to have resistors like the ones below installed on all the LED turn signals.
http://www.ebay.com/itm/2-x-6-OHM-50...81294234928%26
RICHARD
2013 ram 3500
