Old 02-11-2014, 11:02 AM
jsettle's Avatar
jsettle jsettle is offline
Trim Level: Sport 4x4
Rep:212
jsettle has a spectacular aura aboutjsettle has a spectacular aura aboutjsettle has a spectacular aura about
What gearing do you have running those 22"s and 37"s? I LOVE the look of your setup but I don't know about running that setup with the 3.21 gears....
6" ProComp lift with ProRunner shocks, limo tint, 35x12.5x20 Hankook DynaPro M/T, 20x10 Fuel Hostage wheels with -24mm offest, 50" LED light bar with roof mount.
Build Thread: http://www.ramforumz.com/showthread.php?t=160442
Old 02-11-2014, 03:59 PM
Leons Leons is offline
Vehicle: 2013 RAM 1500 4x4 Laramie
Rep:30
Leons is on a distinguished road
Hi Jsettle,
I have the 3.92 gearring (was more luck than wisdom..)
I notice the truck needs a little more effort to do the same now...
I actually drive like an old lady, so I don't even know why it
bothers me as it does... gues it's just the fact that I know
it was snappier before..?
But even If I would have had the 3.21 gearring I would have
done exactly the same setup...
By the way I have the 6 speed.. If you have the 8 speed.. you
will probably notice less difference than me.. even with you're 3.21 gearring..
cheers,
Leon
Old 07-13-2014, 04:53 PM
austin535 austin535 is offline
Vehicle: 2014 ram 1500
austin535 is on a distinguished road
i just ordered a 2014 larmie limited 1500. I think it comes with air bags but wanted to do a 4 or 6 inch lift. How hard was it to remove the airbags? did you need anything additional with the lift kit to compensate for not having the airbags in place anymore?
Old 07-13-2014, 05:26 PM
The coilover in the front helps compensate for the lack of air suspension.
For the rear, its the same. The Coil and Spring replaces what is removed
Old 07-13-2014, 09:52 PM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:19
draken is on a distinguished road
Thats a beautiful truck man.. I am thinking of doing that same set up but with 35's and 18s. how did your gas mileage do with that new set up compared to stock?
Zone 6" Suspension with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 07-21-2014, 12:48 PM
Debonair70 Debonair70 is offline
Vehicle: 2014 Ram 1500
Debonair70 is on a distinguished road
Originally Posted by Leons View Post
the end result...
Great looking truck Leons! Would you happen to have a part # for the rear coils that you used?
Old 07-21-2014, 08:24 PM
We can get that for you and source it for you should you need or want that
Old 07-28-2014, 02:39 AM
Momo2one4 Momo2one4 is online now
Vehicle: 14 Ram 1500 Crew Cab Sport 4x4
Momo2one4 is on a distinguished road
One word. Wow! I'm starting to consider the 6" more and more over the 4". I'm a noob when it comes to lifting but I've seen and read a lot on these forums. Thx!
Ps I wonder if your ride and mpg was affected
Old 07-28-2014, 01:11 PM
Anyway we can help, let me know
Don't think going with a 6" vs a 4" is the right way because you see a lot of pictures.
I would do function over form rather than the reverse
Know what tire size you want to run
Ties into what gears you have as well
Know where you will be traveling to and if your truck would fit
Either way, we can help get you into the right kit for your truck and your usage
Old 07-28-2014, 04:44 PM
Rep:30
Yes the mileage is effected seriously when running 37" tires.. with a 6"lift..it adds up...
* the truck needs more gas to do the same because of the bigger tires..
* more rolling resistance of the bigger tires
* more wind drag because of the extra height
Removing te airbags is as easy as removing regular coils.. ( I left the compressor and other parts in place.. under the bed...)
If I had to do it all over...
wouldn't hesitate a minute....
