Old 01-16-2014, 07:57 PM
bran1093 bran1093 is offline
Vehicle: 2014 Dodge Ram 1500 EXP
bran1093 is on a distinguished road
Updated with more pics
Old 01-16-2014, 07:58 PM
Originally Posted by SShadow1974 View Post
So I looked at the link on Amazon... How do these mount in the light housing?
For the fogs You can zip tie the ballast to the U shaped bar right behind the lower part of the front bumper. Not sure what the actual part is called. But its easy to locate when you have the wheel off and the fender plastic pulled back.
Old 01-16-2014, 11:44 PM
Talon66 Talon66 is offline
Rep:92
Talon66 will become famous soon enough
Your foglights look good, I just switched today from 35w 3000k HIDs, to 4500k 55w HIDs.
2013 Ram 1500 CC Black
Factory: Hemi, 8spd, 4 Corner Air suspension, Rambox
Mods: DIY FX-R Projectors w/4300k & 50w, Custom Dual Relay Harnesses, Tinted, Debadged, blacked out emblems, Stainless Works LT Headers, AVS Low Pro Visors, Magnaflow #12569, Kicker Soundgate, Diablo DCX - HF Tuned
Old 01-17-2014, 03:12 PM
Nicee link me some of your pics if you can!
Old 01-17-2014, 05:51 PM
Rep:92
I will try and get some for you
Old 01-17-2014, 08:57 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
I hope you don't mind, but I have a few more questions...
#1 You have to take your wheels off to change the fogs?
#2 With the 3000k, do you notice a large difference between the stock fogs and these?
#3 Any opinion on how the 3000k would compare with PIAA Extremes?
#4 Where did you mount the boxes (ballasts?)...
#5 How long did it take you to do the work?
#6 Lots of people complain about HID and blinding other drivers... As a fog light, is this still an issue since it is closer to the ground?
Right now, I drive with my fogs on all the time at night because I find the lows are just not bright enough... Especially in the rain. Trying to find the best, lowest cost solution, to rectify this issue.
S S H A D O W
Old 01-17-2014, 10:12 PM
Rep:92
#1 No. Very easy and simple
#2 With HIDs you will notice a huge difference vs stock
#3 HIDs will have a greater output vs PIAA
#4 If you crawl under the truck you will see a good mounting location for mounting the Ballasts
#5 It should take you 10-20 min
#6 I personally havent been flashed with my set up on my 2013
Old 01-18-2014, 11:39 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
How many actually adjust their fog lights, or am I the last one who just realized how simple that was lol. I couldn't believe how much better they were with a few twists on the adjustment tab.
