Old 01-15-2014, 05:19 PM
lostnawave lostnawave is offline
Vehicle: 2008 Dodge Ram 1500
lostnawave is on a distinguished road
Default Newbie level kit install. Thoughts?
Hey guys. I just got my 3" front, 2" rear level kit in (manufactured by All Roads) (http://www.ebay.com/itm/AR-Full-3-Fr...#ht_2008wt_986) and wanted some advise. I was thinking of trying to do this myself as I am somewhat mechanically inclined (2008 1500 extended crew cab 4x2), but i'm having trouble finding a thread with a walkthrough of how to do this. From what I've seen it looks fairly easy, but I don't want to get in the middle of the job and get stuck. Can someone direct me to a walkthrough link or give any advice? I've read some threads where a coil spring compression tool should be used and some where it states it isn't needed (obviously I do not have one). I've also read where an alignment should be done afterwords. Should I just have this one at the shop since it needs an alignment afterwords anyway? Any idea of an average charge a shop should charge to install? So torn! Any advice is greatly appreciated! Thanks!
Old 01-15-2014, 05:27 PM
RamBiker11's Avatar
RamBiker11 RamBiker11 is offline
Vehicle: 2011 Ram 1500
Trim Level: Outdoorsman
Rep:65
RamBiker11 will become famous soon enough
I did mine myself and it really isn't that bad. Youtube is your friend. Tons of how-to videos on there.
Old 01-15-2014, 05:37 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
You could easily do it yourself with a day to spare and some beers and a friend. take your time and dont be afraid to call the supplier with questions.
youtube is your friend.
a shop would probably charge 4-5 hours this particular install. you are looking at an avg of $80-100+ an hour for labor
Old 01-15-2014, 05:45 PM
Sounds good... Think im going to take a stab at it to save. Did you use a compression tool for the springs when you did yours or have it aligned afterwords?
Old 01-15-2014, 05:47 PM
Rep:1900
yes i had to use a spring compressor i rented for free from the local auto parts store to compress the spring and get the the strut out.
and yes absolutely get the truck aligned
Old 01-17-2014, 01:35 PM
Jeringate's Avatar
Jeringate Jeringate is offline
Vehicle: 2014 Ram 1500 Sport
Rep:12
Jeringate is on a distinguished road
youtube, when i was looking for 4th gen installs all i could find was 3rd gen, you're in luck!
2014 Ram Sport White || Bak Industries Roll X Tonneau Cover || Bak Industries Bak Box || Line X Spray In Bedliner || Bilsteins set @ 2.1 || Pro Comp 5001 Wheels 17x9 -6 Offset || Mickey Thompson Baja MTZ 315/70/17 || Mufflex 18" || Various Stickers For More Horsepower ||
Old 02-16-2014, 10:46 PM
BigBlackRam BigBlackRam is offline
Vehicle: 2004 Dodge Ram 4x4
BigBlackRam is on a distinguished road
Pix of the 3"-2" kits installed ?
Old 02-17-2014, 05:42 AM
boomer135 boomer135 is offline
Vehicle: 2013 Ram
Trim Level: 4X4 CC Sport
Rep:39
boomer135 is on a distinguished road
Depending on the type of kit you have you may not have to compress the coils. Post pics of your kit as the link does't describe the kit very well… 100% you will need an alignment. You will notice with your eyes a negative camber
MODS: PE Full Metal Jackrabbit, BT Catch can, Magnaflow 18", Vararam, Bullydog Hemi Tuner, Zone 1.5 BL, Bilstein 5100's @2.8, TG 1.5 rear coil Spacers, Fuel 20x10 -12OS, Toyo OC MT 315/60R20, Painted BW Pocket Flares http://www.ramforumz.com/showthread....88#post1344588
