Suspension Kit?
553 views 3 replies 3 participants last post by  Wandell
#1 ·
I have a 2011 Ram 1500 4x4 with 5.7L and I really like it. It has the 20 inch rims and I recently got new A/T tires. I would like to beef up the suspension so it's stiffer and also give it a bit of a lift (maybe a couple/few inches). I don't have any experience in this area so I read through some discussions here but I'm a bit out of my league.
So I'm wondering if anyone could recommend a kit I could order and have a mechanic install that wouldn't make the existing tires look too small. I'd also like to avoid having to do a bunch of other work to counteract this work but I'd like to have a noticeable difference.
Any help?
#2 ·
what size tires did you get?
1. here seems like a good option
http://www.roughcountry.com/dodge-combo-lift-kit-352.html
i've also seen other 2.5" levels + 1.5" body lifts combos
2. you could just level it with bilstein 5100s shocks (up to 2.8") and add a rear spacer of your choice
3. you could just level it
3. 4" and 6" lifts
4. 3" body lift
or any combination of the above (with a few exceptions)
#3 ·
Also, welcome to the forum! good job finding the correct sub-forum! but be sure to head to the newbie section and introduce yourself
