Old 01-12-2014, 10:07 PM
lostnawave lostnawave is offline
Vehicle: 2008 Dodge Ram 1500
lostnawave is on a distinguished road
Default New leveling kit..too much?
Hey guys...just bought a "full" level kit.. http://m.ebay.com/itm/281111385831?cmd=VIDESC&gxo=true has anyone heard of this one? Is 3 inch front spacer and two inch rear too much stress on the arms? Just want to make sure I'm not going to regret this. Any input is appreciated! 2008 ram 1500 hemi extended cab 4x2
Old 01-12-2014, 10:48 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
You're definitely on the higher end of leveling kits, but I doubt that it'll be exactly 3". I have Daystar's 2.5" kit, which only lifted the truck 2". You'll probably only get about 2.5"... Do you know the actual spacer/puck size? Typically 1.25" = 2", 1 3/8" = 2.5", and 2.5" = 3". If you're actually looking at a 3" lift, then there will obviously be more strain on the ball joints... as well as other linkage connections.
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
Old 01-12-2014, 11:02 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:349
Well, since it is for 2wd only you wont be putting stress on your front drive. Go for it.
333Half the beast
I used to be
Old 01-12-2014, 11:44 PM
Not sure but will measure when I get it in...you're saying you have the 2.5 spacers so have you noticed any stress or made any adjustments to compensate for it?
Old 01-14-2014, 02:30 PM
So the kit should be here tomorrow and the following is the reply I received from the seller. I really hope this isn't going to cause too much stress with my factory ride.
Good morning and thanks for your message. Not a problem at all. Just glad to take care of my customers. The size of the front spacer is roughly 3" and the back is actually 2" tall. The front spacer is Polyurethane and the rear is a steel block
Old 01-14-2014, 02:33 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yeah that polyurethane spacer will squish out some over time.
that's why I dont like them, but...its really your only option for leveling 2wd
