Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Electrical
Old 01-12-2014, 08:02 PM
FarmTruck FarmTruck is offline
Vehicle: 2003 1500 4x4 QuadCab ShortBox
Color: Blue
FarmTruck is on a distinguished road
Default ’03 killing batteries
I keep killing the battery in the truck if I don’t drive it every day or if it gets cold out and I am wondering if there are and common causes or recommended starting points for troubleshooting. I pulled out all the fuses and relays under hood and I see a 0.02 amp draw when I connect an amp meter in series with the battery even after the vehicle is off for 15 minutes.
Old 01-13-2014, 03:30 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
.02 is normal. If you don't have a draw somewhere else greater that .05, I would look at the getting the battery checked to make sure it's still holding it's charge.
Old 01-15-2014, 12:01 AM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
Get it load tested, Mine is doing the same thing. lose my radio presets every time. i'm just trying hold out as long as i can to buy a new battery.
Old 01-16-2014, 12:57 AM
Color: Blue
If I'm getting the typical draw I suspect I have gotten a dud battery. Thank you guys.
Previous owner put a new one in the week before I got it (summer), but it is a low end battery. He messed up the battery retainer when he did it so it seems I'll need drill out the bolt holding it in to get it out, that's why I have not taken it in to get tested. Since I've had the truck I've been using a charger and pulling the negative when it sits.
I'm lucky, I don't loose my presets even when I pull the neg terminal.
Old 01-25-2014, 07:58 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
Autozone can load test it in the vehicle for free if you stop by there. My radio presets stay as well. My truck kills all of the power if I leave something on and everything comes back when I put the key in. I give my wife crap all the time because my dodge won't let me kill the battery by leaving lights on but her ford's battery dies all the time when she forgets lights!
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 02-25-2014, 01:54 PM
Color: Blue
During the last warm spell I pulled the old battery and dropped in a new AGM unit and a battery disconnect. The old battery tested bad when I took it in. It had been drained so many times I saw it as inconclusive so I've been disconnecting the battery when the vehicle is parked and have not had any problems for the last few weeks.
It was supposed to warm up this week so I left the battery connected after I parked the truck Friday. Last night (Monday) I tried to fire it up to pull a neighbour out of a ditch. It was -20c and I only got a half crank at full speed then a couple of slow cranks. Popped it on the charger and it showed ~25% charge.
So I seem to still have a draw issue and I may need to replace or upgrade a few cables. I'll probably wait on cable upgrades until after I get the motor rebuilt or replaced.
Old 02-25-2014, 02:25 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
You may have a draw or is your alternator actually charging the battery?
To me is almost sounds like your charging system isn't charging the battery at all.
I remember when the alternator in my suburban was going out. Made it to autozone and had the battery tested it only showed like 55% charge or something. Cranked the truck over and the alternator failed the regulator and diode test.
Replaced the alternator and no issues after that!
Chrome... in moderation.
Old 02-25-2014, 10:07 PM
Color: Blue
I've been running the battery for some time and had over 50 starts, so there must be some charging. It had tested OK in the fall, but I guess could test again.
