Old 01-10-2014, 04:24 PM
docgatling docgatling is offline
Vehicle: 2012 Ram 1500
Trim Level: Outdoorsman 4X4
docgatling is on a distinguished road
Default LED bed lights
Got a great Xmas from my brother LED bed lights. I want to wire them into the same circuit that with the stock cargo light so they LEDs come on when I switch on the cargo light. I figured Id tap into the power where the cargo light wire originates. For the life of me I cant trace the wires from the roof to where ever power originates. Any idea where this is. I can't find a wire diagram worth anything!
Would it be OK to run the LED wires up the B pillar and attach at the cargo lights. The wires connecting to the bulb look pretty small and I don't want to overload them ( I know the LED don't draw much).
Has anyone tried this. Thanks for the help!
Old 01-11-2014, 10:38 AM
viperr817's Avatar
viperr817 viperr817 is offline
Vehicle: 2012 ram
Rep:195
viperr817 has a spectacular aura aboutviperr817 has a spectacular aura about
I put mine on a switch mounted to my tonno cover rails, in like it much better since i can switch them on at anytime from the bed of the truck.
Old 01-11-2014, 05:26 PM
I guess that's the route I'm going. I'll just tap into the trailer power. reason for wanting to connect to cargo was to prevent someone (wife) leaving them on.
Old 01-11-2014, 06:00 PM
82corvette's Avatar
82corvette 82corvette is offline
Vehicle: 2012 Ram Crew Rambox
Trim Level: Laramie SLT
Rep:128
82corvette will become famous soon enough82corvette will become famous soon enough
I wish someone would post pictures of their led bed lights.
Old 01-11-2014, 10:49 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Rep:156
In another thread, the guy mentioned that it was under the door sill on the drivers side rear door. He even posted a pic or three of it.
S S H A D O W
Old 01-12-2014, 06:34 AM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
I have installed my LED bed lighting strips just as you are describing. Come on when I unlock the truck and then fade out with the cargo light after about 1 minute. If I still want/need them after that timer turns them off, they come back on when I hit unlock again. They also illuminate with the cargo light when I push the cargo light button near the headlight controls.
To acheive this:
Install your strips in the bed and run your wires though the driver side stake post hole, under the cab and up through the floor under the rear passenger driver side seat (flip up your driver side rear passenger seat and then open the storage compartment to see the access point (it is under the carpet) - you can also see the access point by looking under the truck). Drill a small hole the size of your wires, pass them through (add a dab of RTV silicone to your drilled hole after your draw your wires through), run the wires under the rear seat frame and to the driver side rear passenger door sill. Pop the door sill cover off to find the factory wiring harness and locate the cargo light wire (white w/tan stripe). Tap your positive (+) bed lighting wire to the cargo wire and you are done. The negative (-) wire can be grounded anywhere, but to keep my install clean, I kept the positive (+) and negative (-) wires together into the cab and grounded my negative (-) wire to a screw in the rear seat frame.
And some pics of the finished product:
Old 03-30-2014, 09:09 PM
hitman89x's Avatar
hitman89x hitman89x is offline
Vehicle: 2010 ram 1500 slt
Color: metallic gray
hitman89x is on a distinguished road
i need help with thus i installed my lights in my bed today same exact way as KA1OTE and every thing worked for a second then the cargo lights shut off and would not come back on no matter what i did.... is it possible to put to much of a load on this circuit???
Old 03-30-2014, 09:14 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Yes you can definitely put too much on that circuit, this is why I wired mine up via a relay. That circuit drives the coil and I used a fused +ve feed through the contacts to the bed lighting.
Old 03-30-2014, 09:23 PM
hitman89x's Avatar
ok i went out and check and left the cargo light button on while i switched it back and forth from acc to run and the lights would flash on for a second, do you think if i swap out the regular bulbs on the cab to leds that that may lower the load on it??
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
Im getting to install mine on a reed switch at the tailgate. That way theyll only come on when the gate is opened and will shut off when the tailgate closes
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
