Old 01-08-2014, 10:44 PM
Liredneck Liredneck is offline
Vehicle: 2009 1500
Trim Level: TRX4
Rep:15
Liredneck is on a distinguished road
Default 09 TRX4 lift ?
I've been doing some research and I get conflicting answers on the net . Any one lift there TRX4 ? Do the sit .7" higher from the factory ? And that makes it so you can use spacers to level it ? I just want to squeeze 34" or 35" in there whats the easiest way ? Also any pics of a deep water blue trx4 with 34-35?
Thanks in advance
Old 01-08-2014, 11:26 PM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
The short answer is yes. If you install 2" spacer up front, you can clear 35's with the proper offset wheels and or spacers with stock wheels.
