Old 01-05-2014, 06:43 PM
cdyogletree's Avatar
cdyogletree cdyogletree is offline
Vehicle: 2012 Ram 1500
Rep:25
cdyogletree is on a distinguished road
Default 4th Gen front suspension questions
Ok…so I recently put the BDS 6" lift with 5100s set at 1.4 and a rear 3" spring. I thought with this combo the front would end up higher than it did but now I'm not exactly happy.
So my question is, how could I go about getting the front lifted another 1.5"? Is 3" more than the differential drop ok on the stock cvs?
Please let me hear all the knowledge you guys got for me…thanks!
[SIGPIC][/SIGPIC] '12 Ram 1500 lifted and stuff
Old 01-05-2014, 09:51 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Are you wanting to go higher because your truck is still not level? Or do you want the front end to be higher than the rear?
You can go up to 2.8" on the Bilsteins if you really want but it will be harder on parts and give you a rougher ride.
Old 01-05-2014, 10:58 PM
Rep:25
I want the front a tad higher. It sits about perfectly level right now.
I know they can go to 2.8 but I don't like the idea of setting them to max with the 6" strut spacer on top of them…not to mention the right is much much more stiff at 2.8.
Old 01-05-2014, 11:06 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express 4X4
Rep:308
Why is it more stiff at 2.8? Stiffness is in the depth of the stroke not the rebound. There is no difference in ride at any setting until you get to maxing the stroke. That is what they are designed to do.
333Half the beast
I used to be
Old 01-06-2014, 01:00 AM
Rep:2026
You could set them at 2.1" then...
It's not the shock itself that makes it stiffer, it's the angle of the suspension. Because the control arms are at steeper angles (more vertical) more force is transferred up into the frame rather than the suspension absorbing it like when the control arms are close to level.
Old 01-06-2014, 01:07 AM
h2oman's Avatar
Rep:308
I don't doubt your theory. I have mine at 2.8 and they are more plush than stock. Everyone else I talk to says the same.
333Half the beast
I used to be
Old 01-06-2014, 02:13 AM
Rep:25
Exactly what I was thinking but would like more height than just the little over half inch...
