Old 01-03-2014, 01:23 AM
gingy36's Avatar
gingy36 gingy36 is offline
Vehicle: 2012 Ram 1500 Express
gingy36 is on a distinguished road
Default HELP ASAP! Shocks won't fit!
Hey guys I need help. I just got in some rancho 5000 shocks for the front of the truck. I have a 2012 ram 1500 2WD. With a CST 7 inch lift. Anyways, the lift requires me to use stock length shocks. SO the rancho 5000 shocks I ordered are stock length. So I took out the old shocks and got all the way up to putting in the new one. I put on a washer and bushing, then stuck the stem though the coil bucket and hand tightened the bottom two bolts. Next, I have to place a bushing then a washer then a nut at the top of the shock stem (Outside the coil bucket) There is not enough room to put the bushing, washer, and the nut on! The shock is already fully expanded! What do I do?! If I use a longer shock, its going to allow my UCA to hit the coil bucket on full droop. So I must use stock length. If someone could help me as soon as possible as my truck is in the garage on jack stands right now. Thank you!
Old 01-03-2014, 01:51 AM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Read this!
Just remove the "----"
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-03-2014, 02:06 AM
gingy36's Avatar
Originally Posted by RAM357 View Post
Read this!
I appreciate that. I have been looking all around and have found that having longer than stock shocks MAY allows the UCA to hit the Coil bucket at full droop. I already had CSR-1200 15.5" shocks on. They were making clunking noise whenever hitting a dip in the road or going off road. I could not get the top shock nut off so I just cut it off with an angle grinder LOL. So going back to those shocks is not an option..
Old 01-03-2014, 02:17 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
This from the PerformanceLifts.com website:
Shock Absorbers:
CST does not include shock absorbers with this 7" suspension lift. Please note that extended length rear shock absorbers are required when installing this CST 7" lift. You can retain your factory front shock if the budget requires this but it is not recommended. Use of the correct length (slightly longer) front shock will dramatically improve the ride and handling. PerformanceLifts.com offers a number of different shocks available for use with this lift. To help ensure the ride and handling matches the trucks great looks PerformanceLifts.com recommends the CST "CSR" Series shock absorbers. The CST shocks are designed by CST for use with this CST 7" lift. We also offer Bilstein, Rancho and ProComp shocks that we modify for use with this lift. Shock absorbers can be purchased using the drop down selection boxes located beneath this item description.
You should call and see how they modify their shocks for the kit.
Old 01-03-2014, 02:20 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
Shock options
Just go to the drop down menu
Old 01-03-2014, 02:24 AM
gingy36's Avatar
Read the 7th post down by BullRam on the first page. It will explain what I am trying to say.
http://www.ram---forum.com/f40/2wd_l...p_front-24313/
Delete the "---"
Old 01-03-2014, 02:38 AM
gingy36's Avatar
So I ordered stock length Rancho RS5000 shocks so that my UCA would not hit the coil bucket. However I cannot fit the stim/end of shock all the way through. If I put the tire back on and let the jack down to let the tire hit the ground, would i have enough room to put on the bushing, washing, and the nut on?
Old 01-03-2014, 02:55 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
If it doesn't hurt to try, and you don't have a spring compressor I'd try it. Sorry man, 2WD isn't my thing. All I can try and do is point you towards sources of info.
Old 01-03-2014, 02:56 AM
gingy36's Avatar
Yeah I'm going to try that. I appreciate your time man.
Old 01-03-2014, 03:11 AM
RAM357's Avatar
R A M M S T E I N
Rep:580
I wish I could help more man.
Only other thing that comes to mind is fastening the top of the shock and then lowering truck some, to do the lower.
