Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Interior Cleaning and Maintenance!
Interior Cleaning and Maintenance! Keeping the inside clean!
Old 01-02-2014, 07:41 PM
SShadow1974's Avatar
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Rep:156
Unhappy Uh oh... :(
Ok, so I did a helluva booboo...
So I was DD on New Years for a friend's party, so I all I drank was Coke Zero. Stupidly, however, I left a couple cans on the floor of the back seat of my truck... Fast forward to this afternoon... It's been -20c all day and... damnit... the cans of pop exploded in the back of my truck.
The worst of it was frozen to the back of the driver seat and on the headliner in the back seat. I shop vacced the frozen pop up - but it looks like it may have stained the headliner and the seat.
Any suggestions how to clean that up when it gets warmer? I am really upset about it - the truck is less than 2 months old and looks like crap on the inside now.
*depressed*
S S H A D O W
Old 01-02-2014, 08:35 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
coke zero doesn't have sugar right? That's probably a very good thing as far as cleaning it.
Sean
Old 01-02-2014, 08:44 PM
Rep:156
No sugar. But at the moment, it looks like it's stained... But it is too cold to actually try washing it at the moment... It's like -22c outside right now with a blizzard warning for tonight and tomorrow. Fun.
S S H A D O W
Old 01-02-2014, 08:51 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
run to walmart and get yourself something called Folex. its in the cleaning supply aisle. it is the best, safest, and cheapest cleaner out there. amazing.
be careful with the headliner, if you scrub it too hard, it could/fray/ball and detach the glue. just blot the headliner.
Old 01-02-2014, 09:57 PM
Rep:156
Thanks, I will try that as soon as the deep freeze is over.
I could really smack myself around for forgetting that pop back there. Damnit.
S S H A D O W
Old 01-02-2014, 10:03 PM
snrusnak's Avatar
Rep:1385
I think you might be lucky...no sugar should be easy cleanup. Any mild carpet cleaner or similar should work. Just be careful on the headliner like he said above. I think they are normally cardboard, so no rough scrubbing and try to get it only damp, not wet.
Sean
Old 01-04-2014, 02:34 PM
Big Red 1 Big Red 1 is offline
Vehicle: 2014 Ram
Trim Level: Sport Crew Cab
Rep:20
Big Red 1 is on a distinguished road
NEVER saturate a foam backed headliner; the foam will seperate from the backing and or material, especially if it has aged. Use a product called "Tuff Stuff" multi-purpose foam cleaner (Wal-Mart or any auto parts stores). Apply the foam and let set a few minutes (foam will lift the cola out of the material), then use a shop vac to suck up the foam/cola mix being careful to not let the suction "pull" too much on the headliner material. The carpet and upholstery can be cleaned the same way, being generous with the foam, working it into the material with a very SOFT natural bristle brush (never use a stiff brush on upholstery since it will damage it), then use the shop vac to remove all the residue. The key is to use a shop vac/carpet cleaner to remove whatever cleaning solution from the material being cleaned. Been in the auto restoration / detailing business since 1982 and have found this to be fool proof.
Old 01-04-2014, 02:42 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
Is taking it into a professional detailer an option for you? May be a better option than to risk more damage. They would likely be able to return it to like new condition depending on the cost.
Old 01-04-2014, 05:49 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3248
PaulMys has disabled reputation
Well, there is a lesson to be learned here: Always drink on New Years Eve, and let someone ELSE do the driving!
Old 01-04-2014, 08:27 PM
snrusnak's Avatar
Rep:1385
lmao paul... "The ONE time I was responsible, look what happens..."
Sean
