Old 12-24-2013, 11:11 PM
Ryan19 Ryan19 is offline
Vehicle: 2014 Ram Sport Crew 4x4
Trim Level: Sport 4x4
Ryan19 is on a distinguished road
Default 14 Sport Crew, need lift advice
I'm trying to decide which set up to go with and need advice. My truck is a 14 Sport crew 1500 with 3.92, considering a BDS 4", Bilsteins and 35's or BDS 6", Bilsteins and 37's. I will be using the truck to pull my 24ft pontoon boat, any issues with the lifted trucks and pulling?? Anyone know how tall the truck would be with either set up? I'm hoping it will still fit in the garage.
Thanks
Old 12-24-2013, 11:40 PM
LowUFO's Avatar
LowUFO LowUFO is online now
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
You won't get an exact answer on the heights. But around 6'9" or so for the smaller lift and 35s and around 6'11"-7' for the larger lift and 37s.
Simon
Old 12-25-2013, 02:06 AM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
I looked up the 2014 RAM specs:
Height = 74.6 inches
Lets take the tires at face value (35 &37 inches). Your actual figures will vary with brands.
Also note that our trucks sit approx. 3" ass high, but again your actual rake will vary from this. I will use 3" as a standard.
In terms of the lifts, I look at them this way -
4" lift = 4" front & 2" rear (2" is the figure on the BDS site to "level most trucks")
6" lift = 6" front & 3" rear (again to level the truck)
Why the discrepancy in levelling needed I don't know. I know my truck was less than 3" rake and my 6" BDS with 3" rear coil (as they call it) levelled my truck perfectly.
So for argument sake lets say 2" and 3" increases on the rear, and therefore on the roof because the 2 & 3 inches represent the degree of lift ABOVE level.
Stock tires are approx. 33"
So,
Option 1:
74.6" stock height + (35-33)/2 + 2" height increase = 77.6" or 6' 5.6"
Option 2:
74.6" stock height + (37-33)/2 + 3" height increase = 79.6" or 6' 7.6"
It's late so I hope my math isn't too off, but it gives you a roadmap for running your own specific figures. If you want to build more accuracy into it beyond that then measure your rake and tweak the above calculations accordingly.
Merry Christmas
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 12-25-2013, 03:06 PM
Thanks for the info, RAM357 have you tried pulling anything with your truck yet? Could you post a few pics of your truck? According to your profile and mods it appears to be exactly what I'm after.
Merry Xmas
Old 12-25-2013, 04:03 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
Thanks man, you'll love it if you opt for this build.
Unfortunately my wheels were sent in a 6 bolt pattern so for now you and I have to suffer looking at the truck on the stock wheels & tires
Here's one I got at the shop the day the lift was installed. You can see the level stance and get a sense of the amount of lift.
Cheers!
Old 12-25-2013, 04:09 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
I pulled that prank where you repeatedly lock the doors JUST as your wife grabs the handle but thats about it Thats about all I've tried 'pulling'.
I don't think towing would be an issue. Guys have been doing it for decades and just throw on a drop hitch. At least pontoon boats are on the light side, no?
Other than the ram box option we have the identical truck, please post pics when the wheels arrive. Looks level, I like it..this is gonna get expensive lol
Old 12-25-2013, 04:13 PM
The pontoon doesn't weigh that much, approx. 4000lbs total.
Old 12-25-2013, 04:20 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
It does add up, but I look at it not as getting a lift but rather replacing the stock suspension with a higher performance suspension system. And I don't plan on having to do it again. The coil-overs are all rebuildable so that will pay off down the road.
I'll PM you my Canadian supplier I went through. Good, solid guy that I've deal with for 2 decades here.
Cheers!
Old 12-25-2013, 10:40 PM
LowUFO's Avatar
Rep:1105
Due to the OE ride height variances, BDS offers three rear lift options to get your desired stance: 2″ coil spacers, 3″ Pro-Ride coil springs, or 5″ Pro-Ride coil springs.
The different rakes on the Ram 1500 vary from truck to truck and model to model. Variances in suspension, tire pressure, cab design, etc all play into it. Mine measures 6'4" stock. The average rake is 2.75". Mine was 2.6" and I leveled mine w Bilsteins set at 2.1" and it looks dead level. But if you level the truck exactly by measuring the from and back wheel arch heights and installing the corresponding level or lift, you'll find it looks nose high. You need to keep at least half inch to three quarters of an inch of rake for it to look the same.
Simon
