Old 12-24-2013, 07:04 PM
hotwing457's Avatar
hotwing457 hotwing457 is offline
Vehicle: 2011 Ram 1500
hotwing457 is on a distinguished road
Default ABS Wheel Speed Sensor.
hey guys,
i've been getting the U1418 error code (U1418 implausible right wheel distance signal) on my bullydog tuner which is popping the Traction Control, ABS, and Service 4x4 on my dash.
i crawled under my truck and looked at the right rear wheel, and found this sensor loooking thing, with the cable coming out.
i'm thinking its either the sensor thats damaged or the wires/cable coming from it might have been getting pinched from my rear coil springs.
is this indeed my ABS speed sensor?
Duratrac 315.70.17 on 17x9"-12mm / Bilsten5100 2.75" / CoilRiteAirbags / TCC CoilSprings /
Old 12-25-2013, 12:34 AM
Steermaster's Avatar
Steermaster Steermaster is offline
Vehicle: 2004 Dodge Ram
Color: Orange
Steermaster is on a distinguished road
Send a message via AIM to Steermaster
easiest way to tell is go to auto zone/oreilly wherever, and pull on there and match em up
Old 12-30-2013, 04:20 PM
alexac9 alexac9 is offline
Vehicle: 2010 RAM 1500
Trim Level: Lone Star
Color: Cool Vanilla
alexac9 is on a distinguished road
I had the same problem went to the dealer and ordered a kit which had a replacement connection and cables to cut and put together. I can't find the part number but if I find it I will give it to you asap
SFPD 257
Old 02-17-2014, 10:42 PM
Chris In Marshfield's Avatar
Chris In Marshfield Chris In Marshfield is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Hunter Green Pearl
Rep:34
Chris In Marshfield is on a distinguished road
I had the exact same problem. Dealer fixed it in a couple hours under (extended) warranty. Broken wire, they said, but didn't see it myself.
Chris
Old 02-24-2014, 12:06 AM
mastertech10 mastertech10 is offline
Vehicle: 2013 RAM 1500
Rep:12
mastertech10 is on a distinguished road
yeah that guy is your abs sensor. no other codes for that sensor? like a circuit performance/open/circuit high? if no then likely the sensor has failed. If there is circuit codes then normally there is a corroded/broken wire within 6 inches of that connector.
