Old 12-23-2013, 11:27 PM
I push the skinny pedal
Rep:3277
Several guys are running the -44 offsets with a 12.5" wheel and they just scrub the bumper at full lock. There is the -12 offset which is still 1" further out compared to stock. Also, keep in mind that depending on where you are you may be legally required to cover the tire with a fender flare.
Kurtis
Old 12-24-2013, 02:16 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
I don't think it will work with just a 3" bodylift. For wide stance like that, would probably need a 6" suspension lift to clear for rubbing. Most trucks I have seen with that wide of a stance have had 6" lifts.
As Curtis said, you have to watch out for your laws about what is legal. I think in my province tires can't be 3" past the body, so flares are needed for anything over 3" past. Mine are about 2" with 12.50 tires on -12 offset.
Tow mirrors up for the haters
Old 12-26-2013, 07:35 AM
jlyons714's Avatar
jlyons714 jlyons714 is offline
jlyons714 is on a distinguished road
That's a new idea! I may have to give that a try. Thanks for your help! If worst comes to worst, I may need to throw on a leveling kit with my body lift to squeeze them in. But I'll def have to try the cardboard tube idea. Thanks!!
3in. PA body lift - K&N CAI - Halo's & 8000K HID's - 20% Tinted Windows - DSP 93 Perf.Tune
Old 12-26-2013, 07:37 AM
jlyons714's Avatar
I didn't consider the 12 offset either. That's always a possibility. I think I'm going to do a bit more researching on them. I'll keep you guys posted on whatever mods I go with. Thanks for your help!
Old 12-26-2013, 09:02 AM
jlyons714's Avatar
Wonder if I would have the clearance now if I went with -12 or -24 offset w/ just the 3 in body lift? How did yours work out with the -12? Did you have any spacers on the front or fit them with ease?
lift, offset, rim, tire, wide
