Old 01-08-2014, 12:11 PM
Rocky Harbour Rocky Harbour is offline
Vehicle: 2010 Dodge 1500 Ram - Quad Cab
Trim Level: TRX 4 Off Road
Color: Brilliant Black Crystal Pearl / Light Greystone Pearl
Rep:26
Rocky Harbour is on a distinguished road
There are no grease nipples to grease on a Ram truck. I would ask the service department to show you what you had greased.
The only thing I can see that they greased was your wallet. Definitely switch dealers for any other service.
Old 01-22-2014, 01:25 PM
king0145 king0145 is offline
Vehicle: 2009 Ram TRX4
Trim Level: TRX4
Color: Yellow
king0145 is on a distinguished road
As far as I know you cant get a ball joint for the new rams. You have to replace the whole control arm. I'm in the same situation with 60k miles on mine. The dealer wants around $400 for a lower arm.
Old 01-22-2014, 02:05 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
They probably put fluid film on the sway bar links. They squeak sometimes
"There, greased the front end"
It's a chess game with service departments trying to figure out when they're full of it
"I don't care to hear what your ideas are, mine are better"
Old 01-24-2014, 11:43 AM
Trim Level: sport
Color: green
Rep:643
anyone go aftermarket for ball joints?
Old 02-16-2014, 10:49 AM
xtremedurb00's Avatar
xtremedurb00 xtremedurb00 is offline
Vehicle: 2007 Dodge Ram 1500 QC BH
Rep:16
xtremedurb00 is on a distinguished road
Im having the same problem right now with a knocking, creaking noise coming from the front of my truck. I just put a adjustable 5100s on the front and leveled it 2". When I installed them, I also got an alignment and it hasn't even been 5000 miles. Any ideas on what it could be coming from? I've jacked the truck up and shook everything I can get my hands on...still nothing. You would think when they did the alignment, that they would of checked the tire rod ends and ball joints.
20% Tint,Magnaflow Y-Pipe & Exhaust,Jet 180 TStat,NGK V-Power,TB Ground,EFan,Superchips 3865, K&N 57
Old 02-23-2014, 01:05 PM
glcarter's Avatar
glcarter glcarter is offline
Vehicle: 2011 Ram 2500
Rep:49
glcarter is on a distinguished road
Originally Posted by tcuozzo View Post
My 2011 Ram 1500 has 42k miles and no longer in warranty. Over the last few months the front end has been making some knocking, creaking type noises, sometimes loud.
Another reason I went to the 2500 to get away from so many moving parts. I know that the ball joints can fail in a solid axle but, it usually takes longer as they only move in 1 plane instead of multiple. Unless you get silly with tire size!
Just picking brains, mine's worn out!
Old 02-23-2014, 11:43 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
Don't these trucks have 100K mile warranty?
Old 02-24-2014, 12:20 AM
Trim Level: sport
Color: green
Rep:643
100K warranty is drivetrain only.
ball joint, ram ball joints
