Old 12-14-2013, 04:32 PM
Jim012 Jim012 is offline
Vehicle: 2007 ram
Trim Level: St
Jim012 is on a distinguished road
Default Leveling kit with differential drop
I am wanting to level my truck out. Right now I have a 2.5 inch level kit with 2 inch rear blocks. A brand callers supreme suspensions sells a 3.5 inch leveling kit and I know this would not be the best for the truck but it is a high mileage truck anyways. If I did a differential drop with this kit would it be acceptable?
Old 12-14-2013, 05:06 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
You already asked a question almost identical to this in another thread that I replied to. The same answer applies to this situation.... If you want to lift that high you need to start looking at a proper lift kit otherwise you will have problems. Just a diff drop isn't going to cut it. You'll need to drop the lower control arms too. By the time you piece it all together you'd be better off getting a 4" kit from Rough Country.
3.5 inch level, differential drop, level, leveling kit, lift
