Old 12-06-2013, 11:07 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
Default Swaping 06 ram rear end into 98 ram
Does anyone have any advice or opinions to how to make it easier or if anything needs moved or fabricated, or has anyone done it before??
-ken
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 12-06-2013, 01:11 PM
HemiLonestar's Avatar
Rep:274
You will need to see if the leaf spring pads will need to be moved (width wise). Also 06 rear will have rear discs, your original drums. This will throw off your brake bias, you will need a different proportioning valve to get it even again. Will need to verify/modify the way your driveshaft attaches to the pinion (dunno if the 98 has a flange?).
"Big Red"
2006 Charger R/T
Old 12-11-2013, 02:00 PM
98redbull2's Avatar
Color: red
Rep:52
Im not even sure either about the flange but maybe i can get a proportioning valve for the 06 year truck?
And ill probably be swappin a pinion shaft if its not and thatll be a good oportunity to check for bad parts
Mainly were doing the swap for rear disks and limited slip
Old 12-11-2013, 02:18 PM
98redbull2's Avatar
Color: red
Rep:52
The 98 doesnt have a flange and were gonna be puttin a locker in the rear end so we can fix that
Old 12-12-2013, 04:06 AM
dirt dauber's Avatar
dirt dauber dirt dauber is offline
Vehicle: 1999 dodge ram 1500 4X4
Trim Level: STQ
Color: butterscoth gold metalflake
dirt dauber is on a distinguished road
there is a rear disk conversion kit for the 98 ram,
it comes with braided stainless steel brake lines and all hardware for the conversion.
it is just over $2,000 for the kit.
I was going to go this route,but I haven't saved all the money needed yet.
don't know the name of the company that makes the kit,i was going to buy it from a repair shop I know,they were going to order it for me.
custom wheels/all terrain tires magnaflow exhaust K&N intake bed armour bed liner window tint
Old 12-12-2013, 09:16 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
Aside from the physical mods needed for the leaf springs, as mentioned, keep in mind your 1500 springs are 2.5" wide. I don't know if that remained the same for that year AAM axle. Also, you'll have to deal with brake proportioning going to rear disks as more fluid is needed for disks.
Last thing though, assuming this will be used on the street, is that on 98 I recall there is a sensor in the top of the stock rear axle. This is the VSS, vehicle speed sensor. It is used for the speedometer as it reads a toothed ring that is bolted to the carrier/ring gear. Does the AAM axle have that?
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 12-15-2013, 01:57 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
I didn't see where he said it was a AAM
Could be a 9.25
At any rate tone rings are nothing new
"I don't care to hear what your ideas are, mine are better"
Old 12-15-2013, 08:55 PM
Wh1t3nukle's Avatar
Rep:55
The thread title says: Swaping 06 ram rear end into 98 ram
Since 2003 model year the axle vendor was changed from Dana to AAM. A 2006 falls into that change, ergo the OP is talking about an AAM axle.
The front suspension changed to IFS, which isn't new, but the rear axle is an AAM Chrysler 9.25", not a Dana Chysler 9.25". There are differences between the two and the OP is inquiring on swapping the Dana version for the AAM version.
I only offered other potential things for the OP to consider for the swap. In any case, anything can be swapped with time, money, and sweat. But, if the things I mentioned are holdups for preventing the truck to run legally on the street (I don't know if that is important to him), then hopefully he knows that and either dumps the idea, takes on the risk, or is able to find a path. Therefore, the tone ring is part of the swap process as his Dana axle has one. I don't own a 3rd Gen and so I don't know if Dodge did the same in the AAM axle. Hence I thought it would be prudent to mention as there is a sensor to consider.
If the OP is doing this as trail use only/toy thing...then all this is not much risk at all with the assumption of disregarding need for a speedo.
Could be a 9.25
Old 12-17-2013, 03:02 PM
98redbull2's Avatar
Color: red
Rep:52
well we baught the rear end allready and its actually an 03 rear end with the disk setup for 350 bucks with 60000 miles on it and we're tearing it apart anyway to put in a trutrac posi setup in because the truck is 2wd but i think with what we got and the shop we have available to use and the tools we can pull this off pretty well.
as for brake proportioning do you think ill need a master cylinder for this different truck with the rear disk option or just the proportioning block to change it?
and yes the 03 rear end has vss on top like the 98 rear end
