Old 12-14-2013, 04:26 PM
CaptDuff CaptDuff is offline
Color: True Blue Pearl
Rep:159
CaptDuff has a spectacular aura aboutCaptDuff has a spectacular aura about
I believe it was posted somewhere else that if you take the seal off the original headlight and put it on the HID it will stop the looseness and lock it into place better. The original seal was thicker than what some HID's come with.
Old 12-19-2013, 09:42 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Just checked my bulbs. They fit in the housing fine, no moving around. I didn't have to switch seals, but that could be one thing to try. The fogs are easy to get at so some quick seal swaps could save you some money. My bulbs are from HIDSRUS. They are cheap, and tons of colors to choose from. Customer service is bad, but if you want cheap bulbs...
Old 12-19-2013, 09:52 AM
Asur Asur is offline
Vehicle: .
Rep:4371
Seen this also, easy to do
Old 12-19-2013, 07:48 PM
RAMcanNorth's Avatar
RAMcanNorth RAMcanNorth is offline
Vehicle: 2013 Ram 1500 Sport
Trim Level: sport
RAMcanNorth is on a distinguished road
2013 Sport- Was worried about the DRL's in Canada affecting the power output, but the new Canbus is very good and the new projectors don't use either high or low beams for its running lights, so the drl's don't even come into play. Have had 5000k's in for about a month with no issue, no warnings. Even had it into dealer for recall on the flash update for the stability control after the conversion and they didn't even notice the change so I assume all is well with the computers still, no warning codes etc. The cut off is no better then with the infrared dipped halogens but the light output is noticeably brighter. picked them up from absolutehid. Kits comes complete and is all plug an play. requires drilling small hole in cover but has good rubber grommets to seal the hole.
Old 12-20-2013, 05:45 PM
Firemedic10584 Firemedic10584 is offline
Rep:120
Firemedic10584 will become famous soon enoughFiremedic10584 will become famous soon enough
Should of updated - I just added a secondary rubber seal to the bulbs and that snugged them up nicely! Thanks for the advice guys!
Old 01-27-2014, 09:21 PM
berdine3's Avatar
berdine3 berdine3 is offline
Vehicle: 2014 Dodge Ram 1500
Color: Black on Black
Rep:12
berdine3 is on a distinguished road
How is the hids holding up? Want to do this when we get warmer here in ny.
2014 Quad Cab Express Black Edition
Old 06-01-2014, 06:02 PM
jack4656's Avatar
jack4656 jack4656 is offline
Vehicle: 2013 RAM 1500 Laramie Crew Cab
Trim Level: Laramie W/Flare
Color: Mineral Gray w/Metalic Silver Trim
jack4656 is on a distinguished road
Originally Posted by Firemedic10584 View Post
Yes, 9006 fit the projectors fine. Now the fogs I've had an issue with. My first set of 9006 bulbs fit perfect, locked in place fine. But I ordered another pair because I wanted a different color temp and the 9006 bulb I got that time did not lock in place and was loose. I ordered another pair from somewhere else and the same thing. But 9006 fits the low beams fine in the projectors.
It really boggles my mind when I read this. There should be some way to hold these manufactures accountable for marketing something that doesn’t fit correctly. Really! That is why Bulb Socket types/Part#’s & so on exists. Why have them otherwise?
I have been reading POSTS on this forum for days on ways to improve BOTH interior and lighting. I have found some threads that contain information I just have to try and have ordered the components to do just that.
I just want to commend all you people in enlightening (punt not intended) dumb folks like me. I suppose that is why FORUMS exist, for people like me….
____ Click HERE to see Photos of Jacks Toy.____
TruXedo Lo Pro QT Tonneau Cover, Putco Crossrail Side Bed Rails, Two (2) DeeZee tailgate assist, K&N CAI, Husky Liners X-act Contour Floor Liners, Husky Liners Mud Guards, DashMat Ultimat Dashboard Cover, AVS Windflector, AVS Bugflector II, WeatherTech Side Window Deflector, Cabin Air Filter, DRL Mod.
Old 06-02-2014, 09:22 PM
Rep:120
My solution to solve that was to put a second o-ring gasket on the light. That made the lights snug and lock into place how they were meant to.
Old 06-04-2014, 12:54 AM
Leveil22's Avatar
Leveil22 Leveil22 is offline
Trim Level: Laramie Longhorn
Color: Black and Tan
Leveil22 is on a distinguished road
How are the lights doing?
