Old 12-05-2013, 07:12 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I wanted a good quality HID kit with a complete wiring harness to avoid a possible future problem with the TIPM module. I went with Retro Solutions 5000K HID Low Beam Lights 55 Watt installed in my quad headlights.
It was all plug & play and is working for the last 2 months.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-05-2013, 07:47 PM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
I havethe projectors. I was worried about the wiring harness. Looks complicated and I didn't want to drill holes. Was the harness easy to figure out?
Old 12-06-2013, 03:09 PM
jaray jaray is offline
Trim Level: Sport Crew
Rep:197
jaray has a spectacular aura aboutjaray has a spectacular aura about
Do both the Retro Solutions set and Retro Shop system require the plastic housing to be drilled? Is this to make space for the bulb plug or the back of the bulb itself?
Gibson Cat-back exhaust w/black tips, S&B CAI, MGP caliper covers, Recon LED 3rd brake light, Bilstein 5100's, Daystar 1" rear coil spacers, Weathertech floor liners, Westin Ultimate series bull bar, Dee Zee Tailgate Assist, Mopar T- Handle, Kicker speaker upgrade
Old 12-06-2013, 04:04 PM
gcscott's Avatar
Rep:1043
I had to drill 1" hole to get the wires into the light housing with the quad headlamps. There is a rubber cover that goes in the hole and seals well.
The light kits are very easy to install with the wiring harness. Simple plug and play. If you install the kit and have any problems or questions there are many people on this forum to help you. The 3 company's that are listed have very good instructions either online or come with the HID kits.
Greg
Old 12-06-2013, 04:47 PM
Rep:197
Bulbs types- are the ones that come with these kits a common HID style that we can replace from a common bulb manufacturer if we don't like the bulb color or one burns out?
Old 12-07-2013, 01:19 AM
CaptDuff CaptDuff is offline
Color: True Blue Pearl
Rep:159
CaptDuff has a spectacular aura aboutCaptDuff has a spectacular aura about
As much as they prolly are, I wouldn't get bulbs from different manufacturers. They all might have different way of thinking what color range a xxxxK bulb is. So one manufacturer might think a 6000k is more blue, another might think it's more white. So your headlights might be slightly different colors if you get 2 bulbs from 2 different manufacturers.
If I ever get to buying spare bulbs, I'd go with the same company that I have my current HID's from.
Old 12-07-2013, 07:11 AM
gcscott's Avatar
Rep:1043
With HID bulbs you should buy 2 at a time so that the color of the bulb match each other. Even with the original kit manufacture they get shipments of bulbs and are different lot numbers and the color is off a little. So if you buy a replacement bulb (1) it may not match what you received in your kit even though it has the same Kelvin temperature.
Greg
Old 12-07-2013, 04:07 PM
Rep:197
My concern is just getting a new set that fits the new harness. What is the bulb type that the retro shop and solutions use?
I come from some pretty nice white OEM HID's in my BMW and everyones idea of white is different. If I order what I'm told is closest to white (I've decided that would be 5000k) and I get a Christmas tree of blue I'm certainly going to be looking elsewhere for bulbs.
I just dont want to be put in a position where the place I get my HID's from suddenly disappears and I can't get bulbs because they use some proprietary bulb type.
Old 12-13-2013, 06:01 PM
berdine3's Avatar
berdine3 berdine3 is offline
Vehicle: 2014 Dodge Ram 1500
Color: Black on Black
Rep:12
berdine3 is on a distinguished road
So a 9006 bulb fits the stock projectors? I have a 2014. Thanks for the posts.
2014 Quad Cab Express Black Edition
Old 12-14-2013, 01:56 PM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2013 Ram 1500 Sport
Rep:120
Firemedic10584 will become famous soon enoughFiremedic10584 will become famous soon enough
Yes, 9006 fit the projectors fine. Now the fogs I've had an issue with. My first set of 9006 bulbs fit perfect, locked in place fine. But I ordered another pair because I wanted a different color temp and the 9006 bulb I got that time did not lock in place and was loose. I ordered another pair from somewhere else and the same thing. But 9006 fits the low beams fine in the projectors.
