Old 12-02-2013, 11:44 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Sweet man looks great
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 12-02-2013, 11:49 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Originally Posted by silverbullet4 View Post
Hey man truck sounds amazing I just bought the same cam and couldn't find a sound clip on it anywhere. so thanks for that. if you don't mind me asking what other parts did you have to buy? I got the 6.1l pushrods and springs any info would be great thanks
Lets see if I remember all the parts I got. I went with the custom forged pushrods from Inertia. Anyways here's the list:
Crazy Jay Plus Cam
16 6.1L Exhaust Valve Springs
Custom forged pushrods
6.1L timing set (the whole thing, tensioner chain, everything)
Timing cover gasket
5.7L Crank bolt (6.1L is the same bolt also but a different part number)
New Cam bolt
Left and Right head gaskets
2 sets of head bolts (one for each head)
Exhaust manifold gaksets
About 4 gallons of coolant (save some money and buy 2 gallons of pure coolant and 2 gallons of distilled water)
7 quarts oil
Oil filter
Optional: intake manifold gaskets (they are O rings), valve stem seals
I was leaking oil in my heads and burning it off through the exhaust so that's why I replaced the valve stem seals since that seemed to be the problem. My intake manifold gaskets were very oily so I replaced those as well. I would go with FelPro gaskets. They are the company that makes Mopars gaskets. All Mopar does is put their name on them and sell them for more money. So go with the FelPro gaskets. I can see if I can find my list with the part numbers as well and I'll get you that.
Curious how is your exhaust set up?
I'm running a custom made true dual exhaust. Pacesetter longtube headers into 3" piping, no cats, with 3" DMH electric cutouts, into Magnaflow mufflers with 3.5" black slant tips before each rear wheel. I'm essentially running 2 exhausts as I don't have any connection between both sides. No H or X or Y pipe at all.
Headers into piping
Piping to the cutout then muffler
Muffler to tips
Originally Posted by Rollers888 View Post
Your truck sounds mean. I love it. You mention you told them what you were looking to get out of your truck, what exactly do you plan on getting out of it. I want to do a cam swap in the future and I love the way your truck is sounding.
I was looking for alot more bottom end torque. I want to be thrown back in my seat when I hit the gas pedal. I'm never going to need to go 150 mph so I don't need acceleration from speeds like 70 mph. I plan on doing a Sharadon stage III valve body and a 2800-3000 stall converter next. These should also help with what I'm looking to get from my truck. I have taken my truck to the track before and I will probably go again, but being the fastest on the track isn't my first priority. If I can be first from the red light then I'm happy
Supercharged, cammed, other things too!
Old 12-02-2013, 11:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
That's a pretty cool exhaust man. Have you thought about adding an h pipe between them, under the trans? Should help power output a little and would be cheap/easy.
Sean
Old 12-03-2013, 12:01 AM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
I've thought about it but I'm not sure I have a place close enough the put one in. It wasn't my original plan to have the exhaust made this way, but with how I wanted it to look and the placement of things that's how it ended up being made. I have been considering adding an H in there though recently
Old 12-03-2013, 05:48 AM
silverbullet4 silverbullet4 is offline
Vehicle: 2004 Dodge ram
Color: silver
silverbullet4 is on a distinguished road
Thanks man I appreciate it sounds like we got about the se build goin on I just bout the sharadon stage 2 tranny with stage 3 valve body and 3000 stall but my exhaust is a little different I got the pacesetter long tubrs with cat delete but I got two dynomaxx race bullet mufflers they a y pipe with a 4 in tip and I also looked into getting the high volume oil pump too but thanks again for the info
Old 12-03-2013, 07:25 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Looks and sounds mean..You going to add a wide band if not already?
Old 12-03-2013, 10:23 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
That sounds wicked mean bud, definitely jealous!!! looking forward to the WOT video and hearing it scream
Old 12-03-2013, 11:33 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
I've been thinking about it. Would you say its a good idea with everything I've done so far?
Old 12-04-2013, 07:26 AM
Color: Satin Orange
Rep:597
Most definitely. always good to get real time readings of your AFR w/ your mods. Also a important value to whom is doing your tuning.
Old 12-04-2013, 08:48 AM
Asur Asur is offline
Vehicle: .
Rep:4371
Very Nice, sounds really good, a video of the cam replacement would of been so cool
