Old 12-01-2013, 12:36 PM
kevinfrance kevinfrance is offline
Vehicle: 2013 Ram
Trim Level: Longhorn
Color: Brown/Tan
Rep:24
kevinfrance is on a distinguished road
Default 2013 Longhorn 6.7 Diesel Block Heater
I just purchased a new 2013 3500 Longhorn 6.7 Diesel. The options list a Winter Package, but I do not have a cord to plug in the block heater. The dealer tells me that I have to purchase the cord, it doesn't come with the $65,000 truck. Wow. Anyways, how hard is it to install this cord, and which side of the block is the heater in? I traded my 09 Hemi Ram in for this, so this is my first Diesel. Thanks
Old 12-01-2013, 01:40 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
If the Winter package you refer to is the cold weather group, it is standard with the block heater. I had the block heater added to my 2500 and had a problem finding the end of the cord. It was tucked up behind the bumper on the passenger side. I pulled it down a little to make it easier to get at.
Mods: Too many to list
Old 12-01-2013, 09:22 PM
organized mayhem organized mayhem is offline
Trim Level: SLT Big Horn Mega
organized mayhem is on a distinguished road
If it has the cold weather package it most certainly comes with the cord. Check near the tow hook on the passenger side. Thats where mine was hidden. If it doesn't have the cold weather package then you would have to buy the cord. They all have a heater installed.
Old 12-03-2013, 10:16 AM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
I got a cord for the wife's truck for like $20 off ebay or amazon it just plugs right in
Old 12-03-2013, 10:40 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
I bought my cord from http://www.genosgarage.com/
and installed it myself very easy the heater will be on the passenger side of the engine near lower front. It is a very simple install. It will have a cap on it you need to look around with a flash light if you need more help pm me I'll take a pick of mine so you can see where it is.
Old 12-03-2013, 07:13 PM
phobos512's Avatar
phobos512 phobos512 is offline
Vehicle: 2013 Ram 2500 4x4 CCSB CTD
Color: Maximum Steel
Rep:6
phobos512 is an unknown quantity at this point
The cord is dealer installed and some dealers suck, so it's entirely possible OP didn't get the cord. If it's there, you should be able to find it by looking inside the front bumper by the passenger side tow hook area.
The heater is in the block on the right side near the oil filter...It's orange. If the cord isn't installed, you can't miss it.
The dealer sells the cable but a standard Cummins block heater cord will work and they are much cheaper, as someone else noted above.
Matt || 2013 2500 Laramie || CCSB 4x4 CTD || Maximum Steel || Nitto Terra Grapplers 305/70-17s
Old 12-04-2013, 09:42 AM
Iqudayo's Avatar
Rep:563
I installed mine and it took a 5 mins after I found the plug. My truck did not come with the cord attached.
