Old 12-01-2013, 10:11 AM
sprockets sprockets is offline
sprockets is on a distinguished road
Default iPhone only playing iTunes!??!
Hi all,
Before the last update, when I would connect my iphone and play other apps that have sound (pandora, you tube, police scanner etc) the sound would come out just fine, either through bluetooth or through the aux. Now the only thing that i can get to play is the music in my iTunes.
I press pause on the screen and of course everything stops including the other apps on my iphone. I press play and of course iTunes starts playing.
How do I get iTunes to NOT play but allow the other apps to output sound?
I am going nuts trying to make this work like it used to.
Old 12-01-2013, 01:31 PM
OldJoe OldJoe is offline
Vehicle: 2013 Ram 1500 Quad Cab, 8sp
Trim Level: BigHorn. RamBox
Rep:210
OldJoe has a spectacular aura aboutOldJoe has a spectacular aura aboutOldJoe has a spectacular aura about
I had that happen. I shut the phone all the way down, restarted, and problem solved. iPhones can be weird that way and more often then not a restart solves the problem. You have to push your home and off button together until it shuts down. wait about 20 seconds and start it back up. Hope this helps you.
Old 12-05-2013, 08:38 AM
Ok, Ill give that a try. Thanks!
Old 12-07-2013, 08:46 AM
AppFan AppFan is offline
Vehicle: 2013 Ram 1500 CC
Rep:42
AppFan is on a distinguished road
Unfortunately this restart didn't work for me. I'm thinking about going back to the prior software version.
Old 12-07-2013, 01:47 PM
Ramageddon's Avatar
Ramageddon Ramageddon is offline
Vehicle: 2012 Dodge Ram
Color: Mineral gray
Rep:37
Ramageddon is on a distinguished road
Try shutting down I tunes on your phone. Double tap the home button than swipe up the I tune app that should stop it.
Old 12-09-2013, 12:14 AM
I restarted my phone and it worked.. for a day.
The next day I plugged my phone in and immediately the music started playing from iTunes. I pressed the pause button on the ram screen and that effectively muted everything else on the iphone. I would press play again on the ram screen and for a small second I would hear the other app (police scanner) play then the music would start OVER the app so I can hear both the app AND the music at the same time.
How FRUSTRATING!!!
Anyone?????
Old 12-09-2013, 12:16 AM
My last resort is going to be making a long ass song called "AAAAAAA" of 30 minutes of silence.
iphone update aux radio
