Old 11-30-2013, 05:16 PM
captcharles captcharles is offline
Vehicle: 2013 Ram 2500 Laramie CC LB 4x
captcharles is on a distinguished road
Default Newbie help with wirelessone power source
I just picked up my '13 Ram 2500 6.7, CC, LB, 4x. I've got the bags in but I don't know where to get a good power source for the compressor. The "lug" supplied with the kit doesn't fit into the fuse block. I've read different opinions about where and how but very ANXIOUS about getting it wrong.
Any help??
Thanks http://www.ramforumz.com/images/smilies/thk.gif
Old 11-30-2013, 05:46 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Any help??
You can attach a fused power wire to the 3/8" terminal at the end of your fuse block or you can go directly to the battery.
http://i1331.photobucket.com/albums/...ps5831a114.jpg
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-30-2013, 05:59 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Best thing is to get yourself a fuse tap made for your fuse type, then find with a voltmeter a fuse that is only on when the engine ignition key is in the accessories or run position, this way if you park your truck for a while and the weather changes or you develop a leak in your bags, your pump will not work and kill your battery, these wireless One units keep a 5lb load in your bags and when the temperature changes the pressure can go up or down, and it will add or remove air automatically. If you can't find a fuse that you can use, let me know I will check which fuse I used for mine.
Old 11-30-2013, 09:08 PM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
I took a minute with a pair of dikes and needle nose pliers to modify the fuse tap that came with the kit to work with the new little factory fuses. Can't remember which one I tapped in to, just looked at the list on the fuse box lid and picked one that was switched hot.
Have had no problems with it.
- DAA
Old 11-30-2013, 10:05 PM
johnsrt4 johnsrt4 is offline
Vehicle: 2014 dodge ram 1500 5.7 hemi
Color: blue
johnsrt4 is on a distinguished road
welcome to the forums
Old 12-01-2013, 01:33 AM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
I connected my compressor through a relay to keep from drawing too much from the switched circuit.
Mods: Too many to list
Old 12-01-2013, 02:10 PM
Thanks for all the replies. I've forwarded these on to my mechanic.
I appreciate your help.
Old 12-01-2013, 05:21 PM
Default Asur
My guy doesn't really know which one to use. If you could check which you used that would be very helpful.
Old 12-01-2013, 05:30 PM
Vehicle: .
Rep:4371
At supper for the evening, will only be able to check it tomorrow, hope thats ok, I used one of these also, there great for tapping into the fuses.
http://www.ebay.com/itm/Small-ACS-J-...5af94f&vxp=mtr
Old 12-01-2013, 05:43 PM
I appreciate it. Enjoy dinner.
