Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6
Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.6-liter V6 engine - 305 horsepower, 265 lb-ft of torque.
Old 03-22-2014, 10:20 PM
jsl6v8 jsl6v8 is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: HFE
Color: Patriot Blue- Merica
jsl6v8 is on a distinguished road
Originally Posted by Juma View Post
Yes, throttle body.
k, the hose I'm talking about is the the second one on the left behind the throttle body which is causing my confusion.
Old 03-24-2014, 05:27 PM
Juma Juma is offline
Vehicle: 2014 ram crew cab
Trim Level: Tradesman
Rep:13
Juma is on a distinguished road
the left as we look at it from the pic, right?
what is the confusion?
Old 03-24-2014, 05:30 PM
Rep:13
Originally Posted by jlc41 View Post
Got this from Car & Driver article. (Still searching for engine drawing/pcv). The Pentastar is also more compact than the engines it replaces. Chrysler used torque-activated cam phasers that minimize cylinder-head width, so these DOHC heads are no wider than the SOHC heads on prior engines. There’s also a neat space-saving innovation for the PCV system. It employs a camshaft-mounted centrifuge that spins to separate oil from crankcase blowby gasses. The design eliminates the need for larger PCV system plumbing, which Chrysler says shaves two inches off the Pentastar’s height. An added benefit: smaller engines leave more crush space in the engine bay, improving crash-test performance.
yes, every manufacturer using direct injection is trying to find a way to get the oil out of the vapor emitted from the engine venting system. the system described above is supposed to do something like what a catch can does - condense the oil and keep it in the engine but let the other gases leave thru the pcv system and be burned up. the diff is the catch can condenses the oil outside the engine and you have to drain and dispose of it.
Old 03-24-2014, 05:44 PM
hemi4452's Avatar
hemi4452 hemi4452 is offline
Vehicle: 2013 ram crew cab sport
Trim Level: sport
Color: True blue pearl
Rep:69
hemi4452 will become famous soon enough
Nice job
Old 03-28-2014, 08:51 PM
Buckaroo Buckaroo is offline
Vehicle: 2014 Jeep Grand Cherokee
Trim Level: Summit
Buckaroo is on a distinguished road
So, is the bottom line:
1) The line he used was the wrong line?
2) Based on the Pentastar engine design, a catch can is not needed?
My best to all and Hook 'em Horns!!!
Old 03-28-2014, 09:49 PM
Trim Level: HFE
1) Not 100% positive, he has pulled oil from there, and others are using that line, but I personally haven't found any sort of engine diagram to confirm it and I have a hose that goes to the engine with a part number for a PCV hose that goes to a different location, but could be for something else.
2) Based on the engine design with the centrifuge it is much less necessary than say the Hemi, which uses oil like a BP drilling station, but any oil you catch is potentially saving your engine *shrug*
That said I haven't put mine on for lack of confidence/clarification, I'm about to spend the cash to take it to the dealer and have him tell me where the damn thing is.
