Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6
Custom Dodge Ram Performance Mods - Engine - 3.6 Liter Pentastar V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.6-liter V6 engine - 305 horsepower, 265 lb-ft of torque.
Old 11-30-2013, 03:57 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Default Catch Can install for the Pentastar V6
When I removed my engine cover, I found a small puddle of oil at the Throttle Body, oil in the engine cover and in the PCV line. I had only 2000 miles on the truck and none of them were hard driven miles. (no WOT)
I ordered and installed a Billet Technology Catch Can on my 2013 Pentastar 3.6L V6 Engine. I found very little information on installing a Catch Can for the Pentastar Engine.
No one makes a Catch Can Kit for a Ram truck with the Pentastar V6 engine, so I went and ordered a Catch Can Kit from BT. Part # (Billet Technology Signature Series Catch Can 2011 and up Jeep 5.7L, Jeep 6.4L and Durango 5.7L)
The kit comes with 1 Catch Can and mounting bracket, 2 hoses 1/2", 1 double male brass hose connector 1/2" with barbed ends, and 2 screws.
I had to purchase (1) 1/2" brass 90` fitting and (2) 1/2" brass male hose connectors with barbed ends. These 3 parts make up a 90` hose fitting and were purchased at Home Depot.
I mounted the Catch Can on the side of the TIPM wiring box using one existing hole and drilling one additional hole. I used 5/16" hardware.
I removed the PCV hose from the engine cover and cut off 6". Next I inserted the supplied 1/2" double male barbed connector into the outlet end of the PCV hose (one you just cut) coming from the back of the engine. Next attach the supplied 1/2" hose to the connector and run it to the inlet side of the Catch Can.
Next assemble the 3 brass parts to make up the 90` fitting and take the other end of the cut hose (cut down so the brass barbed end just fits) and insert into the barbed fitting. Connect the supplied hose to the 90` fitting and to the outlet side of the Catch Can. Connect the other end to the inlet on the engine cover.
I took 17 pictures and I have them in order of progression with captions.
See the pictures here: http://s1331.photobucket.com/user/gcscott/library/Catch%20Can%20Install%20Pictures?sort=6&page=1
Total cost was about $150
Any questions just ask.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-13-2013, 02:44 PM
ZMW ZMW is offline
Vehicle: 2013 Ram 1500 SLT 4x4 V6
ZMW is on a distinguished road
What is the past # on the catch can? I will follow your instruction and install this next month. Nice write up
Old 12-14-2013, 11:29 AM
gcscott's Avatar
Rep:1043
Line #3 in my post.
Go to there site. The instructions that come with the kit are for a 5.7 hemi engine so you will have to MOD the kit to get it to work. That is what I did in my post. My biggest concern was the inside diameter of the hoses that came with the kit. The hoses were the correct size that I needed and extra long and needed to be cut down.
Greg
Old 03-08-2014, 11:05 PM
jsl6v8 jsl6v8 is offline
Vehicle: 2013 Ram 1500 HFE
Trim Level: HFE
Color: Patriot Blue- Merica
jsl6v8 is on a distinguished road
ok I really hate to ask because there is no good way to say this, are you sure thats the PCV valve hose. If you look at
On my truck I have on that second hose on the left side of the engine if you go back from the throttle body, a parts label on the hose, for part 68083250AA-H which from a simple google search pulls up as a Hose, PCV. I bought a catch can and was going to install it today, I think me and a buddy spent a solid hour debating which hose was the PCV hose, he thought it was the one you used at first and I thought it was the one on the left side of the engine and then I figured well hell there is a part number on the hose just pull it up and it seems to think it is a PCV hose. I've search the internet high and low and as far as I can tell you are the only person to have put the catch can on a ram 1500 3.6L and live to tell the tale, so to speak. Not trying to insult you or cause problems just want to make absolutely certain I have the right hose before I start cutting things and drilling holes into my new truck.
Old 03-09-2014, 12:05 PM
gcscott's Avatar
Rep:1043
I used the hose that is labeled in the picture and I am not 100% sure it is the correct hose. I found oil in the front of my throttle body and the only way the oil could of got there was through this hose that enters the engine intake cover. I also had oil in my engine cover and I cleaned that out using a paper towel which came out with oil on it.
When I did the catch can I had no information on where to attach the hoses that is why I used this hose. I read through many threads on other forums for Pentastar V6 catch cans (none were for the Ram Truck) and picked this hose.
I am not the only one to use this hose. You can look here at another install thread. http://www.ramforumz.com/showthread.php?t=168143
If I have the wrong hose please let me know and please post pictures of what hose you used and do a write up of what you did.
I would like to see more people post what they do to their Pentastar V6 trucks.
Greg
Old 03-15-2014, 02:55 PM
Trim Level: HFE
I still haven't found what I'd be willing to call a definitive answer. I did have one guy say "You don't really have PCV it has a centerfuge on the back of the pass side head run off of the cam" But honestly that answer just doesn't make sense to me.
Old 03-21-2014, 10:30 AM
Juma Juma is offline
Vehicle: 2014 ram crew cab
Trim Level: Tradesman
Rep:13
Juma is on a distinguished road
the PCV line is always plugged in after the throttle plate.
the line you used is to suck air into the engine to circulate back to the intake through the pcv system. It can still get oil in it if the system is not sucking and it normally doesn't suck sometimes which will allow oil to come out there too.
so, the catch can has to be plumbed into the other line pointed out by gcscott.
Old 03-21-2014, 01:20 PM
Trim Level: HFE
Sorry just trying to understand better, when you say throttle plate are you talking about the throttle body? I've had the catchcan sitting in the back of my truck for a while now, haven't felt good about where its suppose to go so haven't done anything with it yet.
Old 03-22-2014, 07:56 AM
Rep:13
Yes, throttle body.
Old 03-22-2014, 12:55 PM
jlc41's Avatar
jlc41 jlc41 is online now
Vehicle: 2013 Ram 1500 CC
Trim Level: Laramie Crew
Color: Western Brown two tone (Hershey Bar)
Rep:39
jlc41 is on a distinguished road
Got this from Car & Driver article. (Still searching for engine drawing/pcv). The Pentastar is also more compact than the engines it replaces. Chrysler used torque-activated cam phasers that minimize cylinder-head width, so these DOHC heads are no wider than the SOHC heads on prior engines. There’s also a neat space-saving innovation for the PCV system. It employs a camshaft-mounted centrifuge that spins to separate oil from crankcase blowby gasses. The design eliminates the need for larger PCV system plumbing, which Chrysler says shaves two inches off the Pentastar’s height. An added benefit: smaller engines leave more crush space in the engine bay, improving crash-test performance.
tint, drop in bed liner, Avs window shades, Raptor bed rails, Dee Zee tail gate damper, Genos cabin air filter, Bak Roll-x cover, Weather tech mud flaps, Recon Xtrem tailgate bar, Moroso catch can, DoMore Slide Step, 5/16 Dual pin stripe, Reese lighted hitch cover, Master lock for hitch receiver, Truxedo bed lites, Hunter SS bull bar, Road Runner embroidered head rests, Plasticolor rear flaps with metal Ram logo, Mopar sill plates.
