Old 11-26-2013, 01:00 AM
DodgeV10 DodgeV10 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Tradesman
DodgeV10 is on a distinguished road
Default High Output Headlight.
Has anyone tried out high output headlights? I can find ones that are 80/100 watts but want to know if anyone else has tried something like that? And will the wires handle the extra watts?
Old 11-26-2013, 01:05 AM
Or has anyone tired out LED bulbs? Like...
http://www.ebay.com/itm/CREE-9008-H1...-/131047840191
Old 11-26-2013, 08:53 AM
Asur Asur is offline
Vehicle: .
Rep:4371
These will melt your bulb sockets and will eventually kill your TIPM The only way you could use these is by running a wire harness made for them, but I have not seen those in a while, by the time you pickup all you need to run those bulbs safely you might as well get a HID kit made for your truck.
These are 11 Watt, just to give you an idea, my Rear Brake lights are 80 watt LED bulbs, how bright do you think 11 watt LED fronts will be?? Don't waste your money, in the long run it will cost you more than getting a HID kit with harness.
go to the lighting section, you can read up about all the stuff I just indicated.
Old 11-26-2013, 09:33 AM
Thank you Asur for the help. Now what is the best headlight out there for the dodge rams? (Low price, long life, easy to retrofit.)
Old 11-26-2013, 01:12 PM
audio1der audio1der is offline
Color: Dark Red Cherry
Rep:201
audio1der has a spectacular aura aboutaudio1der has a spectacular aura aboutaudio1der has a spectacular aura about
Great advice above. Even if you make a harness using heavy gauge wire and a relay, you can actually melt your headlight housing because of the heat cretaed by the higher wattage. I melted my fogs on my car due to this and it's a $$$ lesson.
Watch out for Sylvania "Silver Star" and the like; they overdrive their filaments to produce a little more light for a given wattage, at the expense of lifespan. with how much work it is to replace our bulbs that may be a real factor to you.
I am a big fan of PIAA bulbs. The Extreme Whites put out a gorgeous white light with at least as much output as stock, with great quality.
But each to their own.
'12 Ram 1500 4x4 Sport CC;Airlift 1000, Moroso air/oil can, S&B CAI & scoop, 87mm P/KE/P/TB, Jet 180, Magnaflow
Old 11-26-2013, 02:06 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Go to the lighting section and read the posts for QUALITY HID lights. For low beam you will want 55 watt ballasts, 5000K bulbs give off the most light. Fog lights use 35 watt ballasts, 3000K to 5000K bulbs.
Make sure you get a WIRING HARNESS with each HID kit. It gets it power directly from the battery and only uses the factory wiring to trigger a relay. Make sure it is made for the Ram truck so you don't have problems getting the lights to work. Test the lights before you install them so you know they work.
You can cheep out and get HID light kits (Ebay cheep kits) with Warning Cancellers/Error corrector that don't have a wiring harness. This will put the load and stress on your factory wiring and the TIPM module.
Google: Dodge TIPM and read the problems if you go with cheep HID kits that use Warning Cancellers/Error Corrector!
JMO.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-26-2013, 02:12 PM
Vehicle: .
Rep:4371
You can cheep out and get HID light kits with Warning Cancellers/Error corrector that don't have a wiring harness. This will put the load and stress on your factory wiring and the TIPM module.
Google: Dodge TIPM and read the problems if you go whith cheep HID kits!
JMO.
Greg
Sweet, well said
Old 11-26-2013, 02:41 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
in the subaru world the forum recommended osram sylvania (european sylvania) bulbs. they are the same wattage but put out more lumens and last longer than stock or especially silverstars. don't confuse them with the stuff we can buy here.
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 11-26-2013, 03:19 PM
Vehicle: .
Rep:4371
Have you ever noticed that each time they say in there site or adverts something along the lines of "Brightest bulb available" "no other bulb is as bright as our Osram Sylvania Bulbs" They have a * next to the statement, and if you look at the bottom of the advert or the page this is what you see written next to the *
*Compared to worn standard halogen
Any new bulb will be brighter than a worn standard halogen. yes the color is more white, but that's about it.
in case here is a link
http://www.sylvania.com/en-us/produc...ilverstar.aspx
or
http://www.sylvania.com/en-us/produc...tar-ultra.aspx
Byh the way, Osram Sylvania Inc. is the North American operation of lighting manufacturer Osram. It was established in January 1993, with the acquisition of GTE’s Sylvania lighting division by Osram GmbH.[1]
Old 11-26-2013, 05:24 PM
gcscott's Avatar
Rep:1043
or
When you compare any halogen bulb look at the amount of watts the bulb uses.
Almost all halogen headlight bulbs are 55 watt low beam and 65 watt high beam. The watts are an industry standard and I also believe it is a government maximum limit for road use.
Halogen bulbs above those limits are for off road use only. IE: 80/100 watts or 100 watt and higher.
Osram, Sylvania, and Philips ect. are all the same halogen bulbs, only difference is the glass and the filament used to get a different color of light (Kelvin). So they just appear to be brighter compared to a standard halogen bulb.
Greg
