Old 11-22-2013, 09:28 AM
hesm70 hesm70 is offline
Trim Level: SLT w/Big Horn
Color: Deep Cherry Red
hesm70 is on a distinguished road
Default DDM HID Kit
Anyone with a 2012-2014 install a DDM HID kit in the quad headlamps (non-projector)? I am curious if one uses the "dual-in/Dual out" harness if the error cancellors are needed? I have installed a kit on my son's Dodge Avenger without them but curious if anyone has expierence.
Old 11-22-2013, 10:15 AM
Asur Asur is offline
Vehicle: .
Rep:4371
The rams are pretty finicky when it comes to HID installation, you should email them and give them your truck info, year, etc and gt them to provide you a complete kit that will work with your truck.
Old 11-22-2013, 01:21 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Do a quick search for gcscott (I think that's his username) on the forum. I know he has a DDM kit in his fog lights and I believe he added them in his headlights as well. He's the only one I'm aware of running DDM stuff. Most guys on the forum are using Retro Solutions.
Old 11-22-2013, 04:45 PM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
The Wiring harness kit from DDM tuning has the 2 headlight plug ins, I called and verfied. Now if I am not mistaken they also sell warning cancellors. Since they are like $10 for the pair it wouldn't hurt to order them just in case. Even if you find you don't need them it would save you from ordering them in the future.
My HID kit is from HIDSRUS, canbus 35w AC digital ballast. No wiring harness. I have the projectors though. Once I confirm they continue to work after a little bit I'll do a review. Had them in and working for 2 weeks now.
Old 11-22-2013, 04:50 PM
chuck2417- I installed one of the harnesses on my son's car and it only requires input from one side or the other. I am unsure about the need for the error cancellors yet. My son's 2012 Dodge Avenger did not need them. Actually, I hooked it up and it blew up so I was aggravated and removed it then re-plugged it and it was fine with just the harness with the relay and fuse.
Old 11-23-2013, 11:01 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I installed 35 watt, DDM HID's in my fog lights only. You have to use a wiring harness to get full power to the ballasts. I do not recommend using the Can Bus error corrector/cancelers they put to much stress on the wiring and the TIPM module. JMO.
I have Retro--Solutions 55 watt HID's in my low beam headlights.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-23-2013, 04:20 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2011 Ram
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
have ddm 55 watt lows, with error eliminators and 35 watt fogs with nothing , no issues, only thing is the low tire comes comes on for about 3-5 seconds when u first turn on the lights then everything is great. mines a 2011 should be the same tho
2011 Hemi RCSB Sport 4x4
