Old 11-20-2013, 07:37 PM
Trober's Avatar
Trober Trober is offline
Vehicle: 2006 Dodge Ram 1500 4.7L 2WD
Trober is on a distinguished road
Default Oil questions!
Ive hurd the 4.7s have small oil passages and heavy oil can restrict pressure? I was wondering if i can run 10/30 in the summer months? Im running what it calls for right now cuz its cold (5/30). Will the 10/30 disapate more heat in the summer time? The only reason i ask is cuz i can get 10w/30 part synthetic from work for free!
Im running mobile 1 full synthetic right now
Old 11-21-2013, 07:38 AM
Hornet Hornet is online now
Vehicle: 2013 RCSB Ram
Rep:470
The thinner oil will disappate heat better.
The bigger question is the fact your swapping differant oils,from a full synthetic to a part synthetic,personally i'd stick with one or the other.
Quit being cheap,and stealing oil from your employer.
If you've been running a full synthetic for awhile ,i'd stay with it.
Old 11-21-2013, 08:36 AM
markjr's Avatar
markjr markjr is offline
Vehicle: 2012 ram
Trim Level: Big Horn 4X4
Rep:29
markjr is on a distinguished road
Run it like you have. Yeah, you might save a few bucks for a little while, Lock it up and it'll cost you a whole lot more than the "free" deal. 5/30 is 5/30, Dodge built it, they know what it needs.
Old 11-21-2013, 11:46 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
Yep, agree. Why second guess the engineers who designed the motor? Stick with what is recommended and full synthetic is typically the better choice.
Old 11-21-2013, 07:22 PM
Trober's Avatar
Ive always ran whats recommended and this is the firdt oil change ive given it since i bought it it was simple yes or no ?s i didnt need smart*** comments
Old 11-21-2013, 07:37 PM
Rep:470
Could be the way you posted the question.
You added way too much info lad
Old 11-22-2013, 05:53 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
5w30 vs 10w30 shouldn't make a difference. Where are you located? Might make a slight difference if you are in a cold climate.
"A vehicle's oil has to be thick, but not too thick. It is important that in the winter, the oil be thin enough to allow for the engine to start. But when the engine is warm, the oil must be thick enough to lubricate properly. That's where the numbers come into play.
Neither number corresponds to an actual 'weight,' even though that is the term most people use when referring to motor oil. The viscosity (flow resistance) is tested by allowing a small amount of oil to flow through an aperture. The quicker the oil flows, the lower the rating numbers.
The first number rates the viscosity of the oil at a temperature of 0 degrees F, mimicking cold winter weather, which is why the 'W' designation is added at the end of the first number. The second number repeats the test at 210 degrees F., or normal operating temperature for a fully-warmed engine.
The 'W' rating can be 5, 10, 15 or 20; lower numbers mean the oil is thinner in cold temperatures, necessary for icy climates. The second number rating (meant to represent normal operating temperature of an engine) can be 20, 30, 40 or 50. Warm-weather spots usually require oil in the upper end of that range that can handle extreme heat."
So essentially 5w30 and 10w30 are identical at normal operating temperature. The difference is on cold starts in cold weather.
Also, you must have a pre 08 4.7L, correct? Assuming this based on the oil weight(the 08+ use 5w20).
If you change the oil regularly you won't have any of the so called "common" 4.7L oil issues. They occur when people don't do regular maintenance. I've known a lot of people with 4.7L's (both generations) and nobody has ever had any issues at all with any of their trucks. Same goes for the hemi ram owner's I know. That's why I got a ram, I've seen so many people that I know have such good luck with them.
Sean
