Old 11-20-2013, 11:50 AM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Default Recalibrating speedo post larger tire install?
Hey guys,
I did a cursory check and couldn't find anything for the 2014 Hemi's. I'll be installing some 37's soon, and wonder what solutions are available to recalibrate my speedo after install.
Can a dealership tweak this setting in my ECU or whatever is affected? Do I require a tuner that modifies that datapoint and stays installed under the hood?
I have the 8 speed, which is neither here nor there, but imagine something needs adjustment so any tranny can continue shifting at the optimal points.
Anyone addressing this on their build, or are you guys happy with where the trucks are shifting now?
Thanks!
J
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 11-20-2013, 12:20 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1969
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
At this time there isn't any way to recalibrate the speedo for that large of a tire on a '14. The dealerships can't recalibrate to a size that large and no tuners are available for a '14 yet. Because of that there's no way to tune the transmission either. Right now you're SOL for probably at least 6 months or so before companies start releasing '14 tunes.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | 4.56 AAM/Yukon Gears | S&B Intake w/ Scoop
Old 11-20-2013, 12:23 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
Ok, good to know. In for a crappy winter I guess.
Can you explain the ugly little details that illuminate just 'how' that lack of recalibrating will affect things?
Thanks
Old 11-20-2013, 12:55 PM
Rep:1969
Well the obvious one is that your speedometer will be off. What some guys don't realize is that means that your odometer is off as well. You will actually be driving further than what your odometer or trip meter states. Then going further down the line that means your EVIC fuel mileage will be wrong and your hand calculated mileage will be wrong unless you factor in the percentage of tire size difference into your calculation.
As far as drivability goes it won't be too bad.... especially because you do have an 8 speed. The transmission shift points will be a little off but the truck should relearn and compensate for it a bit.
There are TONS of guys who lift trucks and put larger tires on without ever tuning the truck or recalibrating the speedo. So you don't have a lot to worry about.... It's just not going to be as good as it possibly could be.
Old 11-20-2013, 02:11 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
Well thats confidence building .. right on.
Psst: Is my instantaneous fuel consumption going to 'appear' improved, or worsened? My co-pilot (wife) will have eagle eyes trained on that
The math I can handle. Good points.
Old 11-20-2013, 02:24 PM
Rep:1969
The EVIC will show that your fuel economy is worse because the truck will think you aren't driving as many miles as you actually are. Plus it actually will be worse because of the larger and heavier tires.
Old 11-20-2013, 03:53 PM
Kcbigbadram's Avatar
Kcbigbadram Kcbigbadram is online now
Vehicle: 2012 ram 2500
Trim Level: Bighorn
Color: flame red
Rep:471
one good thing ive found from this problem is my truck thinks it has has less miles then it does. This keeps you under warranty longer than you would normally be.
Old 11-20-2013, 09:52 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
theres a switch you can flick to turn the odometer off... you wont have a speedometer either but no miles will register on your rig (1500 for sure not sur about the 3/4 tons)
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 11-20-2013, 10:40 PM
cvieke's Avatar
cvieke cvieke is offline
Vehicle: 2008 Ram
Trim Level: TRX
cvieke is on a distinguished road
When I put 35s on my truck, the local dealership said that they are not allowed to recalibrate to that size, they are only allowed to recalibrate to the largest factory tire option. My spedo is off by 5mph at 60 mph (actually doing 65).
Volant CAI, Magnaflow muffler, 2" leveling, 3" body lift, Bushwacker fender flares, 4.56 gears
Old 11-20-2013, 10:44 PM
RAM357's Avatar
R A M M S T E I N
Rep:580
I would imagine the RCMP would have an issue with that, and be quite capable of data mining it's activation after the fact. Just saying ..
Yeah, I plan to hit the road with my GPS and get a bead on how far off I am as well. It's my understanding that speedos are off 'up to' 5% on any car rolling off a lot. So you're not bad.
