Old 11-18-2013, 05:31 AM
DodgeRam Maniac's Avatar
DodgeRam Maniac DodgeRam Maniac is offline
Vehicle: 2004 Dodge Ram 1500 5.7l Hemi
Color: Gray
Rep:15
DodgeRam Maniac is on a distinguished road
Default Headlight only working on high beams fix - (video)
2002 - 2006 dodge ram 1500
My right head light stopped working on low beam for some reason and only worked on high beam fuses were good bulb was still good. I had to change my FCM Front Control Module.
https://
YouTube: http://www.youtube.com/user/DodgeRamManiac
Old 11-18-2013, 10:40 PM
Svety Svety is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: Cool Chrome Big Horn
Color: Cool Vanilla
Svety is on a distinguished road
Do you know where the FCM is on a 2010 Ram 1500 5.7? The fuse box is different, I pulled the box but couldn't see the module.
Old 11-19-2013, 11:23 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
The Totally Integrated Power Module (TIPM) is a combination unit that performs the functions of the Power Distribution Center (PDC) and the Front Control Module. The TIPM is a printed circuit board based module that contains fuses, internal relays and a microprocessor that performs the functions previously executed by the FCM. The TIPM is located in the engine compartment, next to the battery and connects directly to the B+ cable via a stud located on top of the unit. The ground connection is via electrical connectors.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-19-2013, 03:52 PM
Color: Gray
Rep:15
what Scott said because I have no idea
