Old 11-16-2013, 09:04 PM
cobblerman cobblerman is offline
Vehicle: 2004 Dodge Ram3500
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
cobblerman is on a distinguished road
Default left brake light out
OK heres the problem, 2004 Dodge Ram3500, lamp out light is on, left brake light is out(but if I hook a trailer to it the trailer light works,truck light does not), bulbs are good, I replaced the IPM (intergrated power module or supply) and it worked for a few days, then went out again, dealer and other mechanics have said it is in the IPM researching the system it shows that the only electrical that is not fused is the tail lights brake lights and suggested that if I put another IPM in it I should fuse those areas so that it wont blow the IPM, another electrical shop said that they could bypass the module for the brake lights. Soooooo any suggestions from anyone short of replacing the $600 IPM and putting fuses in to protect the IPM..
Old 11-16-2013, 09:35 PM
zero zero is offline
Vehicle: 2013 Ram 1500 Express
Rep:99
zero will become famous soon enough
Good luck finding a fuse. You have to have them mailed to you. That is if you can find a dealership in the US that has any in stock.
Old 11-18-2013, 08:57 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
I call shenanigans on this!
I don't know what they tested but how can they condem the junction box if the trailer lights work since they splice into the tail light wiring?
Old 11-27-2013, 11:33 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
i concur. tried testing the wiring before the sockets for pwr?
Old 02-01-2014, 10:41 PM
02Kingstonram's Avatar
02Kingstonram 02Kingstonram is offline
02Kingstonram is on a distinguished road
Did you try a different bulb? Look closely at the small contact wires on the base of the bulb and make sure they have not been bent into the plastic preventing a contact in the socket!
Take that small knife you play with and stick it in between the wire and the plastic at the base of the bulb bending it outward slightly.
Old 02-03-2014, 08:54 AM
tjbiker031's Avatar
Rep:118
Old thread sir...
Old 02-23-2014, 12:12 PM
TooPoorForHemi's Avatar
TooPoorForHemi TooPoorForHemi is offline
Vehicle: 2003 Dodge Ram 1500
TooPoorForHemi is on a distinguished road
I have the same problem as posted here. My Brake light keeps going out. Sometimes the lamp out light flashes on and off repeatedly "dinging" over and over and over and over and over. It's been cold out recently leaving me unable to take the time to diagnose this I'm hoping for warm weather so I can figure this out.
Old 02-02-2015, 07:23 PM
Ostranza's Avatar
Ostranza Ostranza is offline
Vehicle: 2005 Dodge Ram 3500 QuadCab
Rep:68
Ostranza will become famous soon enough
Same issue here. Started with the right break light and was "dinging" all the time until the filament in the bulb would blow. New bulbs only work for about a month. 3rd brake light works fine. Trailer brake lights hooked up to the 4-pin work fine (I have a tailgate light strip hooked up to the 4pin while I try to fix this issue). Originally I thought my rough ride was blowing filaments so I got LED ones...they've only lasted 3months. Right brake tail light was first to go again and now the left or driver side one has gone. While driving down the freeway I get the intermittent "dinging" lamp out indicator but it never stays on so all my voltage checks with a good light bulb or volt meter check out just fine. Hoping I don't have to spend out of my rear end to get this electrical issue fixed so looking here before I give up and go to the dealership..
