Old 11-16-2013, 01:42 PM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Default Headlight adjustment
So on the 2013 projector headlights does anyone know how to adjust the height of the headlights? Maybe it's me but I find they point a little low...? I see the arrows under the hood on each side. The one closest to the headlight assembly appears to be adjusting right and left (has an R and an L with arrows). I looked in the other hole with the arrow but cannot see anything to adjust...
Old 11-16-2013, 02:25 PM
Chefy's Avatar
Chefy Chefy is offline
Vehicle: 2013 Ram
Color: Grey
Rep:29
Chefy is on a distinguished road
Check this thread out. Scroll down a bit and they give directions.
http://www.ramforumz.com/showthread....ght+adjustment
Old 11-16-2013, 02:29 PM
KnuckleHead's Avatar
KnuckleHead KnuckleHead is offline
Vehicle: 2014 Ram 1500
Color: Black/Silver Two Tone
Rep:89
KnuckleHead will become famous soon enough
The one closest to the headlight is up/down. Just did mine the other day. 8mm I think it was.
2014 RAM 1500 Laramie...Ordered 8/3/13, Built 9/10/13, Arrived 10/1/13.
Old 11-16-2013, 02:35 PM
Chefy's Avatar
Vehicle: 2013 Ram
Color: Grey
Rep:29
It's a 7mm or a T20 bit. The hole beside the key fob is where you do your horizontal adjustments.
Old 11-16-2013, 02:51 PM
Rep:2620
it looks like Dodge has made at least one improvement
i don't think mine has 2 adjusters
back of headlight
Old 11-16-2013, 06:36 PM
Rep:158
So it looks like the R and L are misleading. Went outside turned the truck on with the garage door closed and started turning with a T20 screwdriver. It moved the headlights up. Takes a lot of turning to get them to go up or down. I thought it would be like quarter and half turns, but it seems like it takes almost a full turn to see any adjustment... Hopefully it works better now!
