Old 11-12-2013, 09:41 PM
Kaiser68 Kaiser68 is offline
Vehicle: 2012 dodge ram 1500
Kaiser68 is on a distinguished road
Default BDS 6" leveled question
hey guys i go tomorrow to pay for everything but before i do that i want to make sure im understanding everything right.
the bds kit is 6" front and option of 3" or 5" coil in the back. If i get the 3" the truck will be level at a 6" lift correct? 5" i take it is to keep the rake of the vehicle?
also, does anyone think ill need a steering stabilizer?
Old 11-12-2013, 09:53 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
6" w/ a 3" rear coil will keep you level, the 5" rear coil will keep you with some rake, however you can add some bilsteins to the front and still make it level and get closer to an 8" lift, depending on the size of tire/rims you run steering stabilizers generally do not do a lot of good on IFS, however if you are running a large heaver tire, with a big wide rim and have a lot of negative offset I would recommend them.
What price were you quoted for the BDS lift I garuntee you we can beet any delivered price by a good amount. And we can include taxes/duties/shipping into the quote so there is no surprises at the door
Thanks
Jeremiah
Old 11-12-2013, 09:58 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Exactly what Jeremiah said above ^^
