Old 11-12-2013, 04:20 PM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:31
BC18471 is on a distinguished road
Default Pro Tuning Labs
I know that everyone says retro is the best, but I am looking for HID's for heads and fogs, so I am trying to do this on a budget. Pro tuning labs has canbus HID's on sale. Has anyone used these HID's? Canbus allows for it to be plug and play without the errors, correct?
Thank you.
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 11-12-2013, 04:27 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
I will say if you are on a budget i would still spend the 40 bucks from theretrofitsource and purchase the mopar specific harness, and say look into this thread http://www.ramforumz.com/showthread.php?t=157711
Old 11-15-2013, 12:30 PM
Chefy's Avatar
Chefy Chefy is offline
Vehicle: 2013 Ram
Color: Grey
Rep:29
Chefy is on a distinguished road
I just finished doing the install on my projector headlights with the hid conversion from ProTuningLab. At first understanding the relay and the ballists where a little tricky and confusing for me but it is all plug n play from them. I wired my HALO'S and LED'S together and use a quick connect to run a lead off them then wired them into my park lamp wires with another quick connect. Connected my harness to the lights and screwed in the bolts, wired the relay and ballasts to the battery, connected all the ground wires together so i only had one wire to ground off and i was done. I did about 8 hours of research prior and i was more then prepared to do it.
