Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 11-11-2013, 03:09 AM
cfritz2012 cfritz2012 is offline
Vehicle: 2006 Dodge ram
Trim Level: trx4 slt
cfritz2012 is on a distinguished road
Question Vibration for an unknown source
Here's the story. About a month ago I was passing someone a got to a relatively high speed around 95mph I believe. At this speed the truck began to vibrate very loudly in a droning fashion. A few moments later after I got down to high way speed white smoke began poring out the back. long story short transfer case cracked at the rear and pored oil on exhaust. I am not 100% certain (because of the fact at the time my exhaust was very loud and may have muffled any small vibration at highway speed) that there was a vibration before this event. After driving it patched up for a while till I was able to but a new one; a vibration occurred from 50-65 mph 60mph being the worst. After I changed the tcase I assumed that would be the end of it.. Wrong, same vibration no better. I checked for play on the tcase yokes and nothing. The tcase was off of a salvaged 2012 truck with 20,000 miles on it. Checked u-joints for any sign of being bad and they felt fine. Removed front drive shaft all together and still nothing. I have notice that there is beginning to be a slack in drivetrain when going into reverse or drive. My 2 main culprits right now I believe are either a drive shaft balance or maybe rear differential? The vibration is definitely coming from driveline and is not through the steering wheel. The vibration occurs under acceleration, deceleration and constant speed. Any ideas or experiences? Also I will be getting tires rebalance this week. The truck is a 2006 4x4 trx4 1500 with the nv243 tcase, 131,000 miles and a 5.7 hemi QC
Old 11-11-2013, 06:10 AM
Scotian Pride's Avatar
Scotian Pride Scotian Pride is offline
Vehicle: 2013 Dodge Ram 1500
Rep:32
Scotian Pride is on a distinguished road
did you check all the tranny mounts? friend of mine had a similar issue when hitting highway speeds. He went thru and check all the u joints and bearing and all that stuff and it never fixed it he ended up buyin a new truck anyways but if the mounts are gone it would allow for some movement there
Old 11-11-2013, 11:22 AM
Could it have something to do with when I remounted the transfercase? There was a mount under it. That's the only mount I can think of
Old 11-11-2013, 01:00 PM
DonT DonT is offline
Vehicle: 2015 Ram 3500
Trim Level: Tradesman
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:23
DonT is on a distinguished road
Does this truck have a lift kit on it?
2015 Ram 3500 Crew Cab, Long Box Dually 4x4
2014 Ram 2500 Regular Cab, Long Box, 4x4
Old 11-11-2013, 01:42 PM
It has a 2.5 inch front leveling kit but it's been on the truck for over a year without any issues until now
Old 11-11-2013, 08:38 PM
Rep:32
theres definitely a potential for it. did it start immediately after you installed the new transfer case or a little bit after it
Old 11-11-2013, 09:29 PM
david moulding david moulding is offline
Vehicle: 2004 dodge 1500 ram
Color: gray
david moulding is on a distinguished road
I think it's in the transmission
Old 11-11-2013, 11:28 PM
It started imediaty after I installed it. It seems to be coming from the back not the transmition but behind it. There is a thud when switching from neutral to drive or to park and reverse. To me that tells me maybe it's a u-joint? But when I had the drive shaft off there wasn't any slop in them. Also; when the broken transfer case was in It developed a vibration almost the same but not as bad. Once I put in the new one it just got worse
Old 11-12-2013, 02:59 AM
Rep:32
I had a ford ranger when I was younger and I had a very very bad habit of shifting gears in that truck before I brought it to a complete stop. very very hard on the drive line ended up eventually blowing the rear diff all to hell in her. I'd check all the mounts you pulled apart and make sure they're all tight and good if they are you could jack up the ass end of your truck block the front wheels so she don't take off on ya and put it in neutral and get under it and try and turn your rear drive shaft by hand (of your could turn the wheels and watch your shaft) to see if theres play in the shaft before you rear wheels turn if there it you may be losing your rear end
Old 11-12-2013, 03:32 PM
03Ram2500 03Ram2500 is offline
Vehicle: 2003 Dodge Ram 2500
Color: Mineral Gray
Rep:21
03Ram2500 is on a distinguished road
I had a simliar situation or vibration and the driveshaft was installed backwards and it resulted in it being out of balance and creating vibrations at certain speeds. I had work done at a dealership under warranty and they did failed to mark it when reinstalling.
3rd gen ram, driveline vibration, transfer case, vibration
