Old 11-10-2013, 05:19 PM
mkarns mkarns is offline
Vehicle: 1997 Dodge Ram Ext. Cab 4x4
Color: Green/Silver
mkarns is on a distinguished road
Default Need Help from You Experts!
I have a '97 Ram 1500.
I recently replaced the front driver's side headlight assembly.
Yesterday evening I noticed the turn signal part of the new assembly dangling down on the fender hanging by the light bulb cord.
Inspecting it I saw the marker light is supposed to slide in on the side of the headlight assembly, but when I do so there is nothing there to secure it.
My question is can I permanently glue it together with the headlight assembly or will that make replacing the bulb impossible?
I don't really want to buy another whole headlight assembly......
Thanks so much,
M. Karns
Old 11-10-2013, 06:04 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The turn signal slides in. at the bottom (side view) there should be one phillips screw that goes into the headlight bracket. The bottom of the turn signal housing should have two small tabs sticking straight down that the screw goes in-between.
see the little slot in the rear-lower of this one?
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
I thought there was a screw on the bottom farthest away from the bumper. My buddy has a 98 and just changed his out
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 11-10-2013, 07:35 PM
Color: Green/Silver
Default No Screw
Hmmmm.............I don't see any indication of a screw.....
Old 11-11-2013, 08:55 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
^^ Well that must be your problem! haha
Green Interior LEDs
Old 11-12-2013, 10:29 AM
Vehicle: 95
Rep:1776
I'd look at as a plus. I'm sure you've been screwed before so look at as the rare opportunity to be un-screwed.
The headlight housing may be broken, but trust me, there's supposed to be one screw in there to hold it in place.
The how-to moron forgets to tell you you need a phillips screw driver...but uses one to remove the parking light.
http://www.youtube.com/watch?feature...&v=dtzzpuL77bU
