Old 11-10-2013, 05:09 AM
TTR TTR is offline
Vehicle: 2013 ram 1500 sport
Trim Level: sport
TTR is on a distinguished road
Default factory air suspension ???
I have factory air ride suspension a button i push to raise my truck 1 to 2 inches ....Its called off road mode well i would like to deprogram that so when i get to a certain speed it won't lower automatically... Is that possible yet?
Old 11-10-2013, 05:26 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Nope, nothing currently on the market to do what you want. I believe companies are working on it though but it will probably take quite a while to crack the codes to do it.
Old 11-21-2013, 05:35 PM
Leons Leons is offline
Vehicle: 2013 RAM 1500 4x4 Laramie
Rep:30
Leons is on a distinguished road
no need to crack the code:
* THIS IS ON YOU'RE OWN RISK!!!
* set truck in desired ride height
* remove the airsuspension Multi connector
* done
* REALLIGN YOU'RE FRONT WHEELS WITH THE NEW HEIGHT!!!
* I tried this in offroad 2 mode for 2000 miles.. no issues...
No computer errors, just a "airsuspension service" warning at startup
If you put the connector back in it wil function as new
The 9-wire multi-connector is on the passenger side, behind the rear wheel, up under the bed.
met de vriendelijke groeten,
L.
Old 02-21-2014, 03:23 PM
Kylekillerk Kylekillerk is offline
Vehicle: 2013 ram 1500 Laramie with air
Kylekillerk is on a distinguished road
Default Wanna make sure this is still working?
Hey I'm upgrading my truck to a 2014 ram limited which unfortunately I have to get air suspension on it- I've asked the dealer to sell me struts and springs so I can change it they said they can't- want to make sure your method is still working? I'm not lifting just want it to have regular suspension.
Thanks in advance
Old 02-24-2014, 03:20 PM
Rep:30
Yes and no... it kept working, But every once in a while I had to reconnect the multi connector to re-pressirize the system... I recently lifted my truck however... so it is not an issue for me anymore..
But you can just try it.. you can easily undo it, once you reconnect the multiconnector it works as before..
REMEMBER!!!!! you have to re-allign you're wheels... if you decide to keep it in offroad 2...
Watch the angle of you're weels when the truck is in offroad 2, that is why you have to re-allign...
cheers
Leon
Old 02-24-2014, 03:26 PM
Rep:30
And by the way... I swapped the airsuspension alltogether NO problem, see here: http://www.ramforumz.com/showthread.php?t=163874
best,
Leon
