Old 11-08-2013, 06:25 PM
KnuckleHead's Avatar
KnuckleHead KnuckleHead is online now
Vehicle: 2014 Ram 1500
Color: Black/Silver Two Tone
Rep:89
KnuckleHead will become famous soon enough
Default Slight Flickering with Retro Soulitions HID
So I got my kit in last weekend and this week I noticed that my drivers side low beam in flickering or maybe pulsing is a better way to put it. I have contacted Retro and they of course want me to start swapping bulbs and ballasts around, which it understandable, but I am not happy about spending another couple of hours taking my front end apart.
Anywho, here is a vid that lets you see what I am going on about. Has anyone seen this before and/or know what the issue is?
ps, I ran my harness straight to the battery (both pos and neg).
https://www.dropbox.com/s/m47p1wugja...2015.12.57.mov
2014 RAM 1500 Laramie...Ordered 8/3/13, Built 9/10/13, Arrived 10/1/13.
Old 11-08-2013, 08:33 PM
mexi mexi is offline
Vehicle: 2013 Dodge Ram
Trim Level: LARAMIE
Color: MINERAL GREY
Rep:27
mexi is on a distinguished road
mine does the same ..... i just stopped caring ... if they quit im going back stock
Old 11-09-2013, 08:52 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I watched your video and I can see the flickering. You have the engine speed at idle.
(1) Does it do it when you run the RPM up to say around 1000-1200 RPM?
(2) Does it do it with the engine off and lights on?
(3) It looks like you are not getting enough power to the ballast. What other power options, if any, did you install?
Do 1 & 2 first. To trouble shoot, I would run a hot wire and ground wire directly to the ballast, from the battery, which will bypass the wiring harness and see what you get. Next would be swap the bulbs. Last would be swap the ballasts.
I have the Retro H11, 55watt kit installed and don't have this problem.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-09-2013, 10:10 AM
Rep:89
Greg
Yeah, for 1 and 2 it does it at any RPM and with the engine off. I am going to swap the bulbs and ballasts around next weekend when I have the time. It seems to me that it would be a bulb or ballast problem as the other low beam light and both the fogs work just fine.
Old 11-09-2013, 11:06 AM
gcscott's Avatar
Rep:1043
Greg
I was thinking it was just a low RPM issue with current supply to the ballast. Not much fun switching everything around to isolate the problem. (PIA)
Greg
Old 11-10-2013, 07:36 AM
Monster5601 Monster5601 is offline
Vehicle: 2013 RAM 1500 Laramie
Color: Cherry Red
Rep:465
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
I had a similar issue with the retro kit. It was on the passenger side, it started oscillating like yours and became more pronounced.
Turned out to be the ballast.
Old 11-10-2013, 04:30 PM
Rep:89
Ok, thanks. I will start with the ballast.
Old 11-11-2013, 07:36 PM
dodgeboy360's Avatar
Vehicle: 2012 Dodge Ram
Color: Sage Green Pearl
Rep:496
dodgeboy360 is a glorious beacon of lightdodgeboy360 is a glorious beacon of lightdodgeboy360 is a glorious beacon of lightdodgeboy360 is a glorious beacon of lightdodgeboy360 is a glorious beacon of light
I had the retro kit I think.. And it lasted about 3 weeks then my headlights turned into strobe lights so I found it was a bad capacitor so I changed it then 3 days later the lights just shut off on my way to work. I was so mad I just grabbed the side cutters and cut all that bullshit out and put the stock back in. Was a waste of money. But I did love the light the HID did produce so I'm looking at maybe getting a better set up
2012 Ram Big Horn
2" leveling kit/eye brow tint/mufflex 14"/trifecta cover/drop in k&n/Timbrens/285x70R17 Duratracs/5" double walled stainless tips
Old 11-11-2013, 08:21 PM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
My retro kit I have in my fog light flicker more that that but only when it's cold out! Been bugging me forever!
Old 11-11-2013, 08:34 PM
Rep:89
Well, I will post up when I get the time to swap everything around and figure it out.
