Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 3.7L PowerTech V6 Specific Topics
Old 11-08-2013, 04:14 AM
mturbo08 mturbo08 is offline
Vehicle: 2006 ram 3500
Color: gray
mturbo08 is on a distinguished road
Default manuel trans jumping out of 3rd
ok guys im hoping some one here can help before i tear this trans down for nothing. i know i need a clutch a rear output seal and im sure because the output seal is leaking im low on gear oil. could any of those issues cause it to be jumping out of only third gear. or should i go ahead and tear it down and put in new syncros? does anyone happen to have a pdf for teh trans service manuel? and i am a technician at a international dealer but i have never been inside a trans just replaced dozens of clutches.
thanks for all the help
Old 11-08-2013, 08:42 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Try the link below for the manual.
Usually when it jumps out of gear the sychro's are bad.....but read the manual and it may give you other things to look at and check.
Ask around your shop if anybody has experiance tearing into transmissions. They all work the same, just has more gears. But to replace the synchro's you will need a big press.
2003, 3.7, synchro, transmission, veteran
