Old 11-07-2013, 10:10 AM
Trim Level: sport
Color: green
Rep:643
some might argue kitty litter works better than sand if you get stuck.
Old 11-07-2013, 01:26 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1534
Hell use both. Use the sand for weight and the kitty litter for traction. You could even go a step further and use crushed rock.
Magnaflow 14" Custom Install Bilstein 5100s Front Only Set at 2.8" Vararam Air Grabber Cravenspeed Stubby Antenna Dee Zee Tailgate Assist Billet Technology "The Punisher" Shift Knob Debadged doors and tailgate Plasti Dipped HEMI Badge The Punisher Grille and Tailgate Badges Exterior Chrome Delete 20" XD Series 795 Hoss LT305/55R20 Nitto Trail Grappler M/T Cabin Air Filter BAKFlip Roll-X Tonneau Cover
Old 11-07-2013, 01:37 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Ok I have to put my two cents in as well:
Use common sense and be careful leave room between you and others.
On a side note if you remove all the snow from your truck before you travels you will get more HP.
Old 11-07-2013, 03:11 PM
Canadian Hemi Pride's Avatar
stance makes her dance?
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Side note.. I keep my tow straps in my truck all the time and a receiver in the hitch in came you do get stuck someone could give you a little tow or you can help and make even a little cash helping get some vehicles stuck .. Pulled a few cars out of ditches last year
Tow mirrors up for the haters
Old 11-07-2013, 07:59 PM
PaulMys PaulMys is offline
Jan 20. Sad Day
Vehicle: no car
Rep:3238
PaulMys has disabled reputation
Hard to top the advice above. Bottom line is, you have to adjust your driving style to the road conditions. I liken this to driving a boat. I work at a marina and handle several hundred boats a year. 50' twin-screw diesels all the way down to 19' sailboats. When it is calm, you pretty much just get in and go. But when it is windy, you have to formulate a plan and adjust your handling to suit the conditions.
Old 11-08-2013, 10:36 AM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:32
2010x3.92 is on a distinguished road
Paul, I like your style. I too work for a marina who specializes in inboard and v drive boats. With these types of boats you have to think before you act. The reaction to the cause must be thought out. Same thing in winter driving.
I always "test" the surface I am driving on. Weather it be by brake application to test slickness or a little extra throttle to see how easily the tires spin over taking off. Be fully aware and then some and you will generally stay out of trouble save for the other fools who forget how to drive in snow every year.
Old 11-11-2013, 06:39 AM
Hoffman462 Hoffman462 is offline
Vehicle: 2014 Dodge Ram 1500
Hoffman462 is on a distinguished road
Thanks a ton for your posts / responses. Sounds like a lot of good stories and experience. Just one follow up, when people say put some kitty litter on the rear axle, how many lbs do they typically use? 2 bags? (That's about 60 LBS I guess?).
Thanks again for the follow ups
Old 11-11-2013, 12:16 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Keep a snow shovel handy and clear a path for your wheels in the snow or ice and then apply the sand or kitty litter along the path your wheels will travel. You don't need to pile it up, just spread it out and don't spin the wheels.
Also don't tailgate, leave lots of stopping distance. I don't care if I am late to get somewhere and will save time if I don't get stuck or tangled up with someone else.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-11-2013, 12:58 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
One small trick I have learned is to fill your tank up prior to a snow storm. The full weight of gas in the 26 gallon tank is 156lbs. and 192lbs. for the 32 gallon tank. This is an easy way to get more weight on the back end of the truck.
Old 11-12-2013, 12:25 PM
Raz6200 Raz6200 is offline
Vehicle: 2013 Dodge Ram Crew Cab
Color: True Blue
Rep:61
Raz6200 will become famous soon enough
I have grown up in New York and lived here all my life. I now live in upstate New York and get far worse weather than the city. I have driven through countless storms sometimes with 4 wheel drive, sometimes without (mostly when younger) and I can say that you just need to drive defensively and moderately. If you slip remove your foot from the gas, no brake just let it sort itself out in slight slips. If you drive alert and stay at or better yet under the speed limit you will be fine. It's not me I worry about in the snow, it's the other idiots out there that hit the 4 wheel drive button and floor it like it's 90 degrees outside. Those are the people that will slam into you and then act like it wasn't they're fault, they slipped on ice. You can't stop it, but driving defensively will allow you to recognize these people. I also purchased Z chains for the tires. Not sure if I'll ever need them, but they are there packed up in a little case under the back seat. I'm all set for this years snow!
