Old 11-06-2013, 04:54 PM
Hoffman462 Hoffman462 is offline
Vehicle: 2014 Dodge Ram 1500
Hoffman462 is on a distinguished road
Default Winter Is Coming
No, these aren't just the words of House Stark.
Being new to the truck world, what are the tips that you have learned for winter handling and winter driving with your RAM?
I recall hearing horror stories about people saying "Oh I put lots of cement blocks in the back" -- Is this an old wives tale?
Does 4 Wheel Drive help or hurt? I've read so many different takes.
What have you learned from driving a RAM in the winter?
thanks for sharing.
-Dan
Old 11-06-2013, 05:04 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I don't do anything different for winter driving, but then I live in Louisiana, where if they threaten snow or ice they pretty much shut the state down.
Having said that, I've lived and driven where it's cold, wet, snow covered, and icy. I've had both four wheel drive and two wheel drive trucks. I've also pulled lots of people out of the ditch up in Vermont that thought that the four wheel drive would solve all of their driving troubles on snow covered roads (they were proven wrong on numerous occasions).
I would say that 4X4 is an advantage when the roads get a little slippery, though it's not a fix all. You may have four wheel drive, what you don't necessarily have is a specialized version of four wheel stopping. Anti-lock brakes can only do so much.
Put a little weight in the rear, add a bag of sand or kitty litter (the cheap dusty stuff) and use your head while driving and you should be OK.
Welcome to the Z, you'll find this a great place to discover the mods that you never realized that you needed. Be sure to stop by the newbie section if you haven't already for a proper welcome.
Exco
Bill
Old 11-06-2013, 05:15 PM
NewfoundlandRam's Avatar
NewfoundlandRam NewfoundlandRam is offline
Vehicle: 2009 Dodge Ram
NewfoundlandRam is on a distinguished road
I live in Newfoundland which can have some horrible driving conditions in the winter. The biggest problem was outlined above and that is people thinking 4 wheel drive will solve all problems. Sure it will help a lot, but I drive the same speed in two wheel drive as I do in four wheel drive. I find my ram to excellent in the snow and have had to pull a few other vehicles out of the ditch in my travels.
09 Ram 1500 Laramie, 94 Ford mustang, 03 HD Heritage softail, 08 Outlander xt 800, 08 Summit x 800r
Old 11-06-2013, 05:22 PM
Radak04's Avatar
Radak04 Radak04 is offline
Vehicle: 2013 Ram Sport Crew
Rep:76
Radak04 will become famous soon enough
Winter is a subjective term.
Not sure where you live, but here it's snowy, icy and cold. -40 to -50 is pretty common in the dead of winter. Sounds like Louisiana is much more hospitable in the colder months. Different rules apply for different regions.
4x4 will help you get moving, but it won't help you stop or turn. Here winter tires are a must (here).
Weight in the back does help for traction, especially with 2wd vehicles, just be aware that if you hit the ditch (or anything else) any unsecured load in the back will come flying at the cab. I'd stay away from cinder blocks personally.
4WD auto and a good set of tires should be more than enough to keep you safe.
Old 11-06-2013, 07:36 PM
Trim Level: sport
Color: green
Rep:652
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
with out knowing where you live it is hard to help you. i like good all terrain tires. wrangler durtracs seem to be popular hear. i never add any weight in the bed. on ice or pcked snow, slow and steady, no quick turns nd never slam your brakes on. when in doubt, stay home or at work. 4wd is not the "i can do anything go anywhere many people believe it is.
Old 11-06-2013, 08:29 PM
RUSHified's Avatar
RUSHified RUSHified is offline
Color: Blue
RUSHified is on a distinguished road
I clicked on this cause of the GoT reference, LOL But I guess I can reply, umm I live in Los Angeles, so all we get is some rain. I don't really put anything in the bed and at lights as I'm taking off, if the tires spin a bit i just pedal it and its all good. Oh well, good luck you guys.
Old 11-06-2013, 08:42 PM
Canadian Hemi Pride's Avatar
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Last winter I had a large cement block that went against my rubbermaid toolbox and had a strap holding it in secure between my tailgate and the strap. Also have a soft cover too, but never had no issue with it moving when I was messing around in empty parking lots pretending I was a pro drifter or something. 4x4 is excellent is starting to move and continuing moving in bad storms and from stops. Just when you are using it, you want to always be a step ahead and not try to brake hard or turn sharp as if the weather is that bad you will just slide on by. Had no problems last year with my truck, I honestly went to an empty parking lot during/after a bad storm and practised driving through snow and bad weather and how to get used to how your truck manages. My friend somehow never got stuck in his rwd v6 single cab long box GMC, but he did have decent tires and had a secured box for patio stones in the bed right above the rear axle.
Tow mirrors up for the haters
Old 11-06-2013, 08:45 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
The trick to winter driving is smooth and steady. Nothing aggressive and remember..Its not the going that usually causes problems, its the stopping..
Simon
Old 11-06-2013, 08:52 PM
Asur Asur is offline
Vehicle: .
Rep:4371
OK first off I am from Quebec, where the winters are ridiculas, we can get 9ft of snow one year and barely any the year after. There are many things to consider and it also depends on the type of 4x4 you have on your truck.
Here is my Opinion from driving on Quebec, Canada roads for over 35 years
1) your truck is as good as the tires you have on it for snow. ice or the type of winter you have in your area., A 4 season tire does nothing but road ok on pavement in the winter.
2) 4X4 is for getting you out of a snowbank, get you off and rolling in snow, it should not be used as a standard driving setup.
3) Todays trucks with traction control, ABS and stability control will work plenty well in 90% of all Winter situations.
4) If you have 4wd auto, this is nice for most everyday winter driving
5) 4x4 does not mean you can do 100mph on the highway in a snow storm, you will usually be the first one in the ditch.
6) the only weight you want in your bed its a tied down weight, sand bags are the best if you really need it, if you get stuck on ice you have sand to get you out
7) All this info is dependent on where you will live, New York winters are way different then Yukon winters.
Personally I rarely use the 4x4 on the truck unless I need it in a particular situation. Highway I am never in 4x4. you have more control without it. Small city streets full of snow I will use it but up to date in the last 2 years I have used it only once and we have snow storms like you would not believe here.
JMO, Hope this helps you decide what you will need for your area of the woods
Old 11-07-2013, 02:37 AM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
I have a few things to add:
Be EXTRA careful for the first few snow falls of the year. People are going to need to re-learn how to drive. Even those with four wheel drive.
Take your time getting somewhere. You don't want to rush and end up in the ditch or worse. Like others have said the 4 wheel drive can get you out of bad spots BUT if you drive like a maniac it will get you in the ditch deeper.
I personally have never had or needed weight in the back of my four wheel drive trucks. If you live in an area that is rural and the streets don't get plowed right away then use sand as weight like Asur said. It is frikken amazing when you can come to a dead stop at a traffic light on a hill in the middle of a blizzard and take off again like the middle of summer. I will never go without four wheel drive again.
Magnaflow 14" Custom Install Bilstein 5100s Front Only Set at 2.8" Vararam Air Grabber Cravenspeed Stubby Antenna Dee Zee Tailgate Assist Billet Technology "The Punisher" Shift Knob Debadged doors and tailgate Plasti Dipped HEMI Badge The Punisher Grille and Tailgate Badges Exterior Chrome Delete 20" XD Series 795 Hoss LT305/55R20 Nitto Trail Grappler M/T Cabin Air Filter BAKFlip Roll-X Tonneau Cover
